Hey, guys,
I have an Arduino uno Wifi rev 2.
I have such a problem, I am using a BME280 sensor which records some values (temperature, humudity, air pressure) and I am also using wifi to send this data to Firebase database. Everything works more or less fine, the data are updated in the database except for some moments when the data is not sent to the database and the message "Error: connection lost" appears on the serial monitor or it happens that only one of the original 3 values is sent.
This happens terribly irregularly, out of some 10 sends it happens maybe 2x. I've tried connecting to 2 different wifins, I've also tried it on mobile data. Both with the same result.
I have also updated the WifiNINA firmware, currently I have version 1.5.0.
I can't think of anything else to try, please if you can think of anything let me know, I would be grateful for any advice. Thank you
#include <SPI.h>
#include <WiFiNINA.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <Firebase_Arduino_WiFiNINA.h>
//Values for connection
#define FIREBASE_HOST "*******"
#define FIREBASE_AUTH "*******"
#define WIFI_SSID "*****"
#define WIFI_PASSWORD "*****"
//Firebase
FirebaseData firebaseData;
String path = "/IMU_LSM6DS3";
String jsonStr;
//BME280 inicialization
Adafruit_BME280 bme; // I2C
//Wifi connection
Serial.print("Connecting to WiFi...");
int status = WL_IDLE_STATUS;
while (status != WL_CONNECTED) {
status = WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print(".");
delay(300);
Serial.print(" IP: ");
//firebase inicialization
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH, WIFI_SSID, WIFI_PASSWORD);
Firebase.reconnectWiFi(true);
//BME280 setup
unsigned bme_status;
bme_status = bme.begin(0x76);
if (!bme_status) {
Serial.println("There is the problem with BME280 sensor.");
}else{
Serial.println("BME280 sensor is working.");
float x= 32.5, y= 32.5, z= 32.5;
//read data and save them
x = bme.readTemperature();
y= bme.readHumidity();
z= bme.readPressure();
// Send data to Firebase with specific path
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/X", x)) {
Serial.println(firebaseData.dataPath() + " = " + x);
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Y", y)) {
Serial.println(firebaseData.dataPath() + " = " + y);
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Z", z)) {
Serial.println(firebaseData.dataPath() + " = " + z);
// Push data using pushJSON
jsonStr = "{\"X\":" + String(x,6) + ",\"Y\":" + String(y,6) + ",\"Z\":" + String(z,6) + "}";
if (Firebase.pushJSON(firebaseData, path + "/2-pushJSON", jsonStr)) {
Serial.println(firebaseData.dataPath() + " = " + firebaseData.pushName());
else {
Serial.println("Error: " + firebaseData.errorReason());
delay(3000);
