hi guys so i want to build an arduino robot that's connected to the internet using phone then controlled from my computer
so do you have any ideas and do you know any good tutorials ?
You might use key word searches in the forum search box in the upper right of this page. I don't remember anybody using a phone as an interface between a bot and the internet. People have used bluetooth connections between a phone and a bot.
i want to use a phone so i can control the from anywhere
How? How are you going to access your phone when the robot is running all over creation with it?
the robot will be connected to the phone via usb and the phone will use 3G/4G and that's how i will control it using my computer
If I am understanding you right, you want to do something like this:
Computer ---internet---> phone ---USB---> arduino ---> motors, etc (for robot control)
...correct?
There's a number of steps here that you haven't defined - a big one is how you intend to program the phone to interact with the Arduino (also - what kind of phone - android or iphone or something else?). I'm not saying that can't be done - but we need to know what, if any, thought you have given to each section.
From phone to usb - well, that's probably an OTG connection (though you may want to really consider bluetooth here - it's a more established method).
How do you intend to communicate to the phone? I can think of a few ways - but what ways have you thought about?
Do you understand the complexity of the problem you are facing? What parts have you gotten to work, if any (ie - have you been able to get your phone to communicate with the Arduino, or have you been able to remotely communicate with your phone via your computer and (I am presuming) the internet?)
thank you for you're reply
i want to build a robot that's connected to the phone via otg usb and the android phone connected to the internet via 3G/4G and then i will control it with my computer via the internet
so my question is how can i communicate between the computer and the phone to control the robot
like this one - YouTube
The below is posted in the video description, have you read or looked at any of it?
Published on Feb 11, 2013
**documentation : (open the link , then ctrl+s to download).
https://docs.google.com/file/d/0B8Zbq...
**codes explanation:(open the link , then ctrl+s to download).
**source codes : (open the link , then ctrl+s to download).
please notice that the files above are for the version 2.0 of the robot. which can be found here :- YouTube...
This is a web controlled robot ,the commands are sent by clicking on the command button in the HTML interface , there are 5 commands available (up,down,left.right,break) when a specific button (command) is clicked a PHP based server receive the command and using android GCM mechanism the command is pushed to an android based device (samsung galaxy s3 in this case) which is connected to the internet and attached to the ardunio mega adk through usb cable .
when the command received by the android application , the application sends the command to the ardunio adk to move a continuous rotation servos attached to the ardunio board .
-P.S:no Ethernet shield is used or a wireless router , the internet are delivered to the robot through the android device which is connected to 3G internet network.
You can try using Blynk. It seems that it was designed exactly for your needs.
zoomkat:
The below is posted in the video description, have you read or looked at any of it?Published on Feb 11, 2013
https://docs.google.com/file/d/0B8Zbq...**codes explanation:(open the link , then ctrl+s to download).
https://docs.google.com/file/d/0B8Zbq...**source codes : (open the link , then ctrl+s to download).
https://docs.google.com/file/d/0B8Zbq...please notice that the files above are for the version 2.0 of the robot. which can be found here :http://www.youtube.com/watch?v=b5VD5X...
when the command received by the android application , the application sends the command to the ardunio adk to move a continuous rotation servos attached to the ardunio board .-P.S:no Ethernet shield is used or a wireless router , the internet are delivered to the robot through the android device which is connected to 3G internet network.
Hi, Im new to the forum, i have some projects done already. Currently Im working on new project for corona fight - disinfection robot, you can read obout there
This is nonprofit project, and I need solution like this but links are broken, can you upload or send me those links?
Kind regards from Serbia.
