I'm sorry.. because the file is too big seems like it remove my attached file.
the file is down here.
OK, I see what he wants to do.
However there are many things wrong with this idea...
If multiple legs pass S1 or S2 at any time, the timer will start and stop an 'unknown' number of times.
If you forget to manually reset the watch, the times will be meaningless.
The proper approach is either take control of the stopwatch completely, or use the Arduino to do the timing.
lastchancename:
frist of all yeah, I think I just want to reset the stopwatch manually not by a program. and my final goal of this project is to replace SW2 with IR sensor. which is at the finishing line, when a runner passed through the sensor the stopwatch's time will stop. even the system can work on a man and one lap.. it is enough for now.
lastchancename:
- and figure out how to ignore multiple legs - and legs that overlap each other.
can you explain to me what do you mean by 'legs' ?
Runners usually have legs...
aarg:
owh sorry. I thought the other meaning of legs.
