you would probably need some sort of communications interface. If you have a land line you can setup an SMS gateway on a computer. Have the computer parse the SMS message and send it to the arduino via serial. Alternatively, you could use an Ethernet shield, and either have the original computer parse the SMS message from the gateway and send it via Ethernet to the arduino. Or if you are feeling up to it you could write your own sms gateway interpreter that runs solely on the arduino that has wi-fi, ethernet capability.
There are some free implementations of SMS gateways available on linux. I’m not to sure about windoze.
I was thinking about doing the exact same thing with an old but indestructible Nokia 5070 phone.
I have already ordered a $1.25 fbus cable. I think that a serial converter needs to be used
(max-232) and then part of the problem is that programming trunks is not that easy...
but where is the fun if you take that out? I want to make a simple alarm watching a door
with a hall effect magnetic sensor and also use a classical IR sensor. Also, I plan to user the
nokia battery to power the whole thing, and the original nokia charger. This alarm will be totally
silent. If there is a break in, only an SMS will be sent to my phone and maybe to my mother's.
Also I was thinking that it should be possible to make arduino answer an incoming phone call,
if you want to listen to whatever is going on at your place.
As I live in Argentina, most GSM shields will not work here (must be 4 bands or at least
have the 850 Mhz band)... the ones available are way too expensive. This experiment will cost
me close to nothing. The phone has been lying around for years... the rest of the parts I already
have.
The beauty of this is that you can do a lot of things. I want a custom alarm, just because I cannot
think of another use, but if you live in the country side and you want to control remotely things
that are really far away, like water pumps or some other stuff, this can be an option.
There is a lot of info about Nokia trunk programming in the web. I can post advances when my
cable arrives and I start playing with this.
Hi, i'm interesed to control few relays via Arduino and GSM phone. Some old phones we can bought much chiper than any specialized modem or shield.
It will be nice to get nokia 6300 or similar to work via USB interface.
Anyone did some trys?
I got stuck with this project as the SMS frame for Nokia 5070 is not published and even gnokii will not know how to handle it.
I was thinking about downloading the nokia suite, log the com port and try to figure out the frame differences, but I have
not had the time to do so...
On the other hand, if the phone is supported by gnokii, it is possible to make it work.
I did develop a library of c functions to set up the frame, including the generation of checksums and 7 bit coding.
If you can sniff and analyze phone-pc communication, you can install Mobiledit with c.r.a.c.k, It allow to read SMS data and it is done via USB. So that can be better for future.
I want program for gsm based home device control system
arduino uno and sim 900 is used here ..using 3 devices
anyone help mee??
My project works going on but i didnt get output..i think it is the mistake of my program..
help me
anyone help mee??
help me
