Hello,
I would like to use an Arduino to control a stepper motor output stage with a clock and direction signal. Does anyone have any experience of how long the step signal needs to be for standard output stages? Does anyone know of a way to generate the step signal in the required length without a delay?
Thanks
Hans
The step pulse us usually 10 micro seconds or longer. Use delaymicroseconds(10);
delayMicroseconds(10); // upper case M
Thanks.
So are you doing this through a stepper motor control board or through, e.g., a power transistor connected to a GPIO on the Arduino?
I ask because I am wondering what the purpose of specific board is if a 10+ millisecond pulse to a transistor alone will cause a step?
I know there are things like micro-stepping that probably get complex. But, if we are talking about "no frills" is the:
Arduino GPIO ---> Power Transistor* --> Device (load)
Acceptable, or is there something bad about that?
* Or a TRIAC if the load is something that can use AC, such as a heating element rather than a motor.
