Hi
for the realization of a speed controller for three-phase induction motor, I realize an inverter (6 IGBT) (the attached picture)
So I have to control this inverter.
I did a search in our forum I found this:
http://forum.arduino.cc/index.php?topic=121727.0
I tried this code on arduino uno (Atmega328p). but i didn't obtein a good results:
one of the three phase is not correct. i think that the problem is the dead time. in addition to that i don't find a solution to varying the frequency.
does any one help me.
thanks in advance.
* DDS Sine Generator mit ATMEGS 328
* Timer2 generates the 31250 KHz Clock Interrupt
* Use Timer2 Interrupt to change duty cycle for the output PWM signals
* D. Tolken
* 120 degress out of phase signals for 3 phase BLDC motor controller
* CPUT, South Africa
a Huge thumbs up and thanks must be given to Martin Nawrath for the developement of the original code to generate a sine wave using PWM and a LPF.
Link:
http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/
#include "avr/pgmspace.h" //Store data in flash (program) memory instead of SRAM
// Look Up table of a single sine period divied up into 256 values. Refer to PWM to sine.xls on how the values was calculated
PROGMEM prog_uchar sine256[] = {
127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,
242,243,244,245,247,248,249,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,
221,219,217,215,212,210,208,205,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,87,84,81,78,
76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,
33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit)) //define a bit to have the properties of a clear bit operator
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))//define a bit to have the properties of a set bit operator
int PWM1= 11;// PWM1 output, phase 1
int PWM2 = 3; //
