Hello everybody, I’ve been searching a lot for a solution but couldn’t figure it out.
I need an expert suggestion,
Anyways, my project is Arduino UNO - connected with a motion sensor so it works as a switch for on and off command.
The problem is how can I connect a separate circuit electric toy, which it has it’s own battery to work. I think the toy cannot work with the arduino output voltage and current not enough to preform the toy. That’s why I need to use the toy’s battery to make the toy work.
So the motion sensor give a command to toy circuit to start once the motion sensor detects a movement.
I finished with the motion sensor, assembly and programmed.
My problem is how can I connect the toy circuit into the arduino board, So the motion sensor can switch on the toy circuit?
Should I just disconnect the push button switch which it is in the toy circuit and just connect it direct to the Arduino pins?
Can the motion sensor command the toy’s circuit to start?
Should I use zenerdiod so the toy’s battery won’t go the arduino board?
Please advises my friends
Anyone know how to solve my case, I will be thankful ![]()
