Control Surface - Disable all CCRotaryEncoders
Hi all,
still working/learning on the mighty Control-Surface library.
I have a 3 buttons & 3 encoders circuit.
Would it be possible to disable all the CCRotaryEncoders whenever a Note button is pressed.
I tried flagging the encoders but it didn't work:
bool allencodersEnabled = true;                             // Flag to enable/disable all
OR
bool allCCEncodersEnabled = true;                             // Flag to enable/disable all
Any ideas? Thanks
CCRotaryEncoder encoders[] { ... };
  Control_Surface.loop();
  if (/* button pressed */) {
    for (auto &enc : encoders)
      enc.disable();
  } else if (/* button released */) {
      enc.enable();
Thanks @PieterP.
CCRotaryEncoder encoders[3] {
{21, 20},      //pins of encoder 1
{19, 18},      //pins of encoder 2
{15, 14}       //pins of encoder 3
But now can I create an array of encoders? Or more specifically, I can set the MIDI address to each encoder?
Thank you!
Use a pair of braces for each level of initialization: one for the array, one for each element of the array, one for each argument to the CCRotaryEncoder constructor (if it is initialized with more than one values).
For example:
  {{21, 20}, {0x10, Channel_1}},
  {{19, 18}, {0x10, Channel_2}},
  {{15, 14}, {0x10, Channel_3}},
