Hello I am fairly new to programming and Arduino in general.
I have searched countless forums for the answer to my question but I can't find anything that applies.
I am currently working on a robot that has different motions.
Two servos will be powering one leg of the robot. One of the servos will control the vertical motion (from an angle -60 degrees to 60 degrees). The other one will control a rotation from -45 degrees to 45 degrees. I am able to program these motions separately, but I hope to achieve the motions simultaneously. So as it moves vertically there will also be the rotation. Both of the motions will happen in the span of 1 second, and it will go backwards as well.
I need to be able to do this on two legs (so four servos) and then there will be an additional servo that will go from -45 degrees to 45 degrees in 1 second as well.
With these parameters how can use arduino to program this motion?
In addition to this, I know to not power the servos through the Arduino board, I am using a 4 AA battery pack, since I have 5 servos, should I consider using an additional 4AA battery pack to power the larger servos?
The servos I'm using are:
2 Hitec HS-805BB Mega Power
2 Hitec HS-646WP
1 Micro Servo 9g A0090
Thank you for reading this inquiry, any help would be greatly appreciated.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
