Hi there! recently my GOVEE light strip stopped working and I was researching to see if there was a way to control it using my Arduino. I have not found anything about that. anyways these are the lights I have and help would be much appreciated
Yes, you can.
The circled part is where you inject your external 24v and send the data (DI = data in) from your Arduino... and the shared GND/ground.
It worked! thank you so much! you saved me from buying another.
Add a 1000uF cap across power and a 330ohm resistor on the data pin. Verify this info.
Hey can i ask which library you used with your Govee lights? I've been trying to do the same thing with 12V RGBIC Govee lights and I can't get the Adafruit Neopixel library to work.
I used the fastled library just the example code for it.
Hope you are well,
Christopher S.
Thank you so much for the reply! I will try using that. This is my first time using a coding forum and, seeing how many disappointing unanswered threads there are, your reply is very encouraging!
Best wishes in your programming endeavors,
N. Daggett
