As the title says for a project I want to control 9 electromagnets with an arduino uno. The idea is that it will become a 3x3 grid. The motors I currently want to buy are: elektromagnet 5kg - 12V DC - JF-XP2520 with a resistance coil of ~55Ω. I am currently in the process of thinking about the best circuit. I don't want to use a electromagnet module since I want to place the magnets as close to eachother as possible. So far I think I will need the following for every magnet:
10 kΩ gate pull-down resistors
100–220 Ω gate resistor (for between arduino and MOSFET, or do I not need this?)
1N4007 diodes
N-channel logic-level MOSFETs (IRLZ44N, IRLZ34N?)
Does this seem reasonable? Or am I missing something? I based it on this schematic I found online.
Be aware this will use 9 pins from your Arduino, which is not a problem if you do not connect much else, either sensors or switches etc.
If you need to connect more devices to the Arduino you could look at e.g. an MCP23S17 which has 16 IO channels and can be controlled over SPI (only 3 pins instead of 9 pins).
Does that include reversing the magnetic field? Looks like, so far, you are just controlling the current to the magnet. Have you investigated how long it will take for your electromagnet field to go away after the current is turned off?
I am not sure yet if I want to reverse the mangetic field... I am working with living magnetic material so not sure how it responds yet... but I guess that would make the circuit a bit more difficult. In the end (if it works) I would also like to scale up to a bigger grid say 10 x 10
So I am working with a micro-organism that is magnetic (its movement can be steered with a magnet).... but after some brief thinking I think it would be best if I could reverse the polarity.
I am suspecting that you do not know the strength of the magnetic field you are attempting to create. What are the real specifications for your electromagnets?
No i don't know... but it doesn't have to be that strong, since it also work with a more 'weaker' magnet and the organism itself is ofcourse very light
Can you explain more about this?
Do you mean you want to control 100 magnets in a 10 x 10 grid? So potentially 200 outputs if you want to be able to reverse the magnetic field. Or are you thinking of wiring them as a matrix? Or something else?
