I am new with Arduino, I have a device that is powered by an AA battery. The device also has two buttons that change the modes of operation. I wish to power and control the device using Arduino. I have attached the picture for reference. Any help is appreciated.
Controlling the power to the device is as easy as using a relay but controlling the buttons depends on the circuit of the device. Can you establish what the buttons do ? It would be common for them to take a point in the circuit to either GND or 1.5V
A clumsy solution would be to use relays to mimic the action of pressing the buttons
Do you have any details of the circuit ?
Do you have any details of the output ? It may be possible to replace the whole thing with an Arduino rather than trying to control what you have
I guess that device has a voltage step up circuits because 1.5 volts may not be enough for those leds.
If you don’t want to analyze circuit to explore any possible optimisation measures, then use 3 relay modules and a 1.5 volt regulator (with matching capacitors).
Is there a switch which is not visible in the picture or how is the device powered on ?
Can you measure the current from the battery to the device when it operating?
Have you an oscilloscope to view the output waveform?
It is not a remote control device. It is from an "infrared therapy device". I'll leave it to the OP to produce links if he wants to. The circa 4kHz infra red infra red signal was the clue.
Anyway, focussing only on the technical issues and ignoring the application area, it is interesting that the manufacturer chose a more complex design which a boost converter instead of simply using an extra AA cell. It could be that being ultra compact was important for this market segment. I guess that the startup current could be quite high and may not be a suitable load for a USB power supply, meaning that any Arduino solution to switch the device may be best retaining a battery.
I imagine also that it would be possible to create a pure Arduino solution., i.e. one having a similar effect to the original. It is probably not critical that the wave form of the original device is duplicated with a high level of fidelity. That is, if the OP is interested in reverse engineering the device with a view to building a replica of it.
6v6gt:
Yes, It is an electric therapy device, it gives electric shocks of the specification I mentioned earlier. And yes I wish to build a solution that is purely Arduino-based, but I do not know how? That is why I switched my focus to controlling that circuit with an Arduino rather than creating a new one. Also replicating this device is not of much importance to me, all that matters for my project is to connect it to the rest of the system and trigger its operations based on parameters received from other devices.
Currently, I am able to connect the device to an Arduino using a relay and a AA battery. But still confused with how to connect the buttons to be able to fully control the device with Arduino.
It would be nice to at least know how the buttons are configured? If the buttons just make a momentary ground with one side held high by a pullup then a few simple NPN transistors like a 2N3904 could have emitter (ground) and collector (high side) placed across each button, drive the bases with your uC. How is the device normally turned on and off?
Paul__B:
It must be quite sophisticated as it provides "Auto-detection of meridian energy points". At least it is "Safe and effective, with no side effects".
I rather suspect that it is Safe and (in)effective, with no side effects
