Wiring the SK6812 LED strip to an Arduino Uno is relatively straightforward. The SK6812 LED strip consists of individually addressable RGB LEDs, and it requires only one data line for communication.
Here's a wiring diagram that showcases the proper connections between the SK6812 LED strip and the Arduino Uno:
Arduino Uno SK6812 LED Strip GND -> GND 5V -> 5V D6 (or any digital pin) -> Data
Connect the GND pin of the Arduino Uno to the GND pin of the SK6812 LED strip. Connect the 5V pin of the Arduino Uno to the 5V pin of the LED strip. Finally, connect a digital pin (in this example, D6) of the Arduino Uno to the Data pin of the LED strip.
Now, let's move on to the example code. The code below demonstrates how to control the colors and effects of the SK6812 LED strip using the FastLED library, which provides easy-to-use functions for working with addressable LED strips.
First, you'll need to install the FastLED library in your Arduino IDE by going to "Sketch" -> "Include Library" -> "Manage Libraries" and searching for "FastLED".
`#include <FastLED.h>
#define DATA_PIN 6
#define NUM_LEDS 10
CRGB leds[NUM_LEDS];
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
// Set all LEDs to red
fill_solid(leds, NUM_LEDS, CRGB::Red);
FastLED.show();
// Set all LEDs to green
fill_solid(leds, NUM_LEDS, CRGB::Green);
FastLED.show();
// Set all LEDs to blue
fill_solid(leds, NUM_LEDS, CRGB::Blue);
FastLED.show();
} In this example, we include the FastLED library and define the data pin (DATA_PIN) that is connected to the Arduino Uno, as well as the number of LEDs (NUM_LEDS`) in your strip.
In the setup() function, we initialize the FastLED library to work with the SK6812 LED strip using the addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS) function.
In the loop() function, we demonstrate three simple color effects. Firstly, we set all LEDs to red using fill_solid(), then we display the colors on the LED strip using FastLED.show() and introduce a delay of 1 second. We repeat the process for green and blue colors.
You can modify this code to create various patterns and effects with the SK6812 LED strip by referring to the FastLED library documentation and exploring its capabilities.
Remember to adjust NUM_LEDS to match the number of LEDs in your specific SK6812 LED strip.
