Im working on a robot using arduino mega (food serving robot) and the code was working fine until i added sound functionality. It worked till there were IR sensors array, bluetooth module, motor driver ,arduino keypad, ultrasonic sensor. but as soon as i added mp3 tf module and speaker to play sound, it started malfunctioning and not working acc to code. Im not able figure out the issue.
CODE:
#include <Keypad.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <NewPing.h> // Include the NewPing library for the ultrasonic sensor
#include <SoftwareSerial.h>
#include "DFRobotDFPlayerMini.h"
bool hasPlayed = false;
bool isStopped = false; // Flag to track if playback is stopped
#define BT_RX A8
#define BT_TX A9
SoftwareSerial btSerial(BT_RX, BT_TX); // RX, TX
// Define the trigger and echo pins for the ultrasonic sensor
#define TRIGGER_PIN 14
#define ECHO_PIN 52
NewPing sonar(TRIGGER_PIN, ECHO_PIN); // Create a NewPing object with the defined pins
// Define a threshold distance to detect obstacles (in centimeters)
#define OBSTACLE_THRESHOLD 5
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {53, 51, 48, 47}; // Connect to the row pinouts of the keypad
byte colPins[COLS] = {45, 43, 41, 39}; // Connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
int s1, s2, s3, s4, s5, s6, s7, s8;
const int ENA = 10; // PWM pin for Motor A speed control
const int IN1 = 22; // Motor A input 1
const int IN2 = 24; // Motor A input 2
const int ENB = 11; // PWM pin for Motor B speed control
const int IN3 = 26; // Motor B input 1
const int IN4 = 28; // Motor B input 2
int mode = 0; // Variable to store the selected mode
bool firstIntersectionPassed = false;
bool specialCaseActivated = false;
bool turned180 = false;
#define OLED_RESET 50
Adafruit_SSD1306 display(OLED_RESET);
static const uint8_t PIN_MP3_TX = 13; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 12; // Connects to module's TX
SoftwareSerial hardwareSerial(PIN_MP3_RX, PIN_MP3_TX);
DFRobotDFPlayerMini player;
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
pinMode(8, INPUT);
pinMode(9, INPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
btSerial.begin(9600);
hardwareSerial.begin(9600);
if (player.begin(hardwareSerial)) {
Serial.println("OK");
// Set volume to maximum (0 to 30).
player.volume(30);
player.playMp3Folder(1);
delay(6000);
player.playMp3Folder(2);
Serial.println("Connecting to DFPlayer Mini failed!");
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(10,0);
display.println("FOOD SERVING ROBOT");
display.setCursor(0,5);
display.println("---------------------");
display.display();
delay(3000); // Delay for 3 seconds to display the greeting
display.setCursor(15,15);
display.println("CHOOSE A TABLE");
display.display();
bool tableSelected = false; // Variable to indicate if a table number has been selected
int prevMode = 0; // Variable to store the previous mode
if (btSerial.available()) {
char key = btSerial.read(); // Read the character received from Bluetooth
if (key == '1' || key == '2' || key == '3' || key == '4') {
mode = key - '0'; // Convert char to int
Serial.print("Selected Table: ");
Serial.println(mode);
specialCaseActivated = false; // Reset the special case flag
display.print("Selected Table: ");
display.println(mode);
display.display();
else if (key == '0') {
turn180Degrees();
specialCaseActivated = true; // Set the special case flag
Serial.println("Return Button Pressed");
display.setCursor(0,0);
display.println("Return Button Pressed");
display.display();
char key = keypad.getKey();
if (key != NO_KEY) {
display.display();
switch (mode) {
case 1:
player.playMp3Folder(3);// Replace with your actual file name
case 2:
player.playMp3Folder(4); // Replace with your actual file name
case 3:
player.playMp3Folder(5); // Replace with your actual file name
case 4:
player.playMp3Folder(6); // Replace with your actual file name
default:
turn180Degrees();
display.display();
// If mode has been selected, start line following
if (mode != 0) {
// Read sensor values
s1 = digitalRead(2);
s2 = digitalRead(3);
s3 = digitalRead(4);
s4 = digitalRead(5);
s5 = digitalRead(6);
s6 = digitalRead(7);
s7 = digitalRead(8);
s8 = digitalRead(9);
// Check for obstacles using ultrasonic sensor
int distance = sonar.ping_cm();
if (distance <= OBSTACLE_THRESHOLD && distance > 0) {
// Stop the motors if an obstacle is detected
motor_stop();
// Print "OBSTACLE AHEAD"
display.print("OBSTACLE AHEAD");
display.display();
// Wait until the obstacle is cleared
while (distance <= OBSTACLE_THRESHOLD && distance > 0) {
delay(50); // Adjust delay as needed
// Clear the display to revert back to normal
display.display();
// Line following
lineFollow();
void lineFollow() {
// Black = 1, White = 0
// Forward
if (
((s1 == 0) && (s2 == 0) && (s3 == 0) && (s4 == 1) && (s5 == 1) && (s6 == 0) && (s7 == 0) && (s8 == 0)) ||
((s1 == 0) && (s2 == 0) && (s3 == 0) && (s4 == 1) && (s5 == 0) && (s6 == 0) && (s7 == 0) && (s8 == 0)) ||
((s1 == 0) && (s2 == 0) && (s3 == 0) && (s4 == 0) && (s5 == 1) && (s6 == 0) && (s7 == 0) && (s8 == 0)) ||
((s1 == 0) && (s2 == 0) && (s3 == 1) && (s4 == 1) && (s5 == 1) && (s6 == 1) && (s7 == 0) && (s8 == 0)) ||
((s1 == 0) && (s2 == 1) && (s3 == 1) && (s4 == 1) && (s5 == 1) && (s6 == 1) && (s7 == 1) && (s8 == 0))
forward();
// Right
else if (
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==1)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==1)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==1)&&(s7==1)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==1)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==1)&&(s6==1)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==1)&&(s7==1)&&(s8==1)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==0)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==0))
right();
// Left
else if (
((s1==1)&&(s2==0)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==1)&&(s2==1)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==1)&&(s3==0)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==1)&&(s3==1)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==1)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==1)&&(s4==1)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==1)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==1)&&(s8==0)) ||
((s1==1)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==0)&&(s8==0)) ||
((s1==1)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==1)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==1)&&(s2==1)&&(s3==1)&&(s4==0)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==0)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==0)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==0)&&(s7==0)&&(s8==0)) ||
((s1==0)&&(s2==1)&&(s3==1)&&(s4==1)&&(s5==1)&&(s6==1)&&(s7==0)&&(s8==0))
left();
// Stop
else if ((s1 == 0) && (s2 == 0) && (s3 == 0) && (s4 == 0) && (s5 == 0) && (s6 == 0) && (s7 == 0) && (s8 == 0)) {
if (!hasPlayed) { // Check if playback has not occurred yet
motor_stop(); // Stop the motors
Serial.println("Stopped");
player.playMp3Folder(7); // Play file 7
hasPlayed = true; // Set the flag to indicate playback has occurred
// Reset the flag if sensors detect anything other than white
hasPlayed = false;
// If all sensors are on the line and a mode has been selected, turn left or right
if ((s1 == 1) && (s2 == 1) && (s3 == 1) && (s4 == 1) && (s5 == 1) && (s6 == 1) && (s7 == 1) && (s8 == 1)) {
if (specialCaseActivated && turned180) {
if (mode == 1) {
right(); // Change behavior for table 1
Serial.println("Returning From Table 1");
display.print("Returning From Table 1");
display.display();
} else if (mode == 2) {
left(); // Change behavior for table 2
Serial.println("Returning From Table 2");
display.print("Returning From Table 2");
display.display();
else if (mode == 3) {
forward(); // Change behavior for table 3
delay(800);
Serial.println("Returning From Table 3");
display.print("Returning From Table 3");
display.display();
else if (mode == 4) {
forward(); // Change behavior for table 4
delay(800);
Serial.println("Returning From Table 4");
display.print("Returning From Table 4");
display.display();
if (mode == 1) {
left();
Serial.println("Table 1");
display.print("Table 1");
display.display();
right();
Serial.println("Table 2");
display.print("Table 2");
display.display();
else if (mode == 3){
if (firstIntersectionPassed) {
left(); // Turn left at the intersection
Serial.println("Table 3: Turned left at intersection (subsequent)");
forward(); // Move forward without turning
Serial.println("Table 3: Moved forward through intersection (first)");
delay(1000); // Delay to ensure the robot fully crosses the intersection
firstIntersectionPassed = true; // Update the flag to indicate the first intersection is passed
right(); // Turn right at the intersection
Serial.println("Table 4: Turned right at intersection (subsequent)");
else {
Serial.println("Table 4: Moved forward through intersection (first)");
void forward() {
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
analogWrite(ENA, 130);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
analogWrite(ENB, 130);
void right() {
digitalWrite(IN1, LOW);
analogWrite(ENA, 0);
analogWrite(ENB, 170);
void left() {
analogWrite(ENA, 170);
digitalWrite(IN3, LOW);
analogWrite(ENB, 0);
void motor_stop() {
void turn180Degrees() {
// Stop the robot
motor_stop();
delay(500); // Add a small delay for stability
// Set the motors to rotate in opposite directions
analogWrite(ENA, 150); // Adjust the speed as needed
digitalWrite(IN4, HIGH);
analogWrite(ENB, 150); // Adjust the speed as needed
// Delay for the time needed to complete the turn
delay(1500); // Adjust the delay based on the robot's turning performance
// Stop the motors
motor_stop();
turned180 = true;
