Controlling servo motor from WS2811 output
Hey,
I'd like to control a servo motor using the output of a WS2811. The only purpose of the WS2811 is to decode the LED data, and I plan to use just one of the channels (e.g., Red) to control the servo.
I'm considering two approaches:
  • Convert the Red channel’s PWM signal to a DC voltage, then use a microcontroller to read that voltage and generate a suitable PWM signal for the servo.
  • Directly convert the Red channel’s PWM signal into a servo-compatible PWM signal without using a microcontroller. This would be ideal since it eliminates the need for programming.
Does anyone have experience with this or any advice on how I could achieve it?
First of all i need to ask you why you want to achieve this, because it really is quite a tricky thing to manage and direct reception of a WS2811 signal does require quite a fast MCU. I am not saying it's impossible, just that it is really hard, and that there may be better and simpler solutions to achieve your end goal.
I can think of a circuit in which you have a ws2811 to receive the signal, you filter the 1KHz PWM to a steady voltage and measure that with say an ATtiny13 which can then send out a pulse to the Servo, or you try and capture the 1KHz PWM signal directly and send the pulse to the Servo from that result (this is probably the easiest) Also for this an ATtiny13 should suffice.
Maybe a picture would better explain what I'm trying to do.
Basically, I'd like to use the data line of the WS2811 for the servo aswell as for the LEDs.
This way, I don't need 2 seperate the data lines, which makes it so much simpler for my project.
As you said, I can see 3 solutions :
  1. Only using a uC, decode the signal but it might not be easy.
  2. Using a WS2811, it decodes the data, generates a PWM. Filter the PWM to steady voltage and measure it with a uC.
  3. Using a WS2811, it decodes the data, generates a PWM. Somehow, without any uC, transform this 1kHz PWM to a 50Hz PWM that would work for the servo.
What do you say? How would the filtering on lets say the Red channel work? Just a simple RC filter with with R channel and GND?
That part was clear to me, but that was not quite the question. What is your project ? this is the question. Where will you put it ? How do you intend to control it ?
This is the most straightforward way and if i would not use a separate data line, that would be my method of choice.
I am again saying 'if' i would not use an extra dataline, because probably that would be my method of choice unless using an extra data line would complicate matters for reasons like "the whole thing will be revolving" or "I am mounting it on a drone" or something like that.
The easiest solution is pretty much the extra dataline, though i understand that you may think that using the WS2811 dataline may be more practical.
Anyway, i assume you have a loose WS2811, and the parts to connect it for either 5v or 12v. (the voltage system you are using is relevant, if your whole system is already 5v this simplifies matters a tad.)
The 50Hz PWM for the Servo isn't actually a 50Hz PWM. The requirement is a pulse being sent with a duration between usually about 500uS & 2500uS and the length determines the angle. The pulse should be sent no more often than every 20mS, but if it's not send quite that often this is also OK.
The WS2811 outputs are open-collector and you should put a 10K pullup on the output, and then connect it to the interrupt pin of the ATtiny (i assume you will go for that, it is the smallest and a 13a easily will do the job) And use a timer/counter to determine the duty-cycle. From that you can calculate the length of the pulse you want to send. Once you have send the pulse you can restart the process.
Please describe the exact scenario in which you think this is an easier solution, because if the base controller is say the VJ-booth in a club, i would simply do DMX to Servo, and if the base controller is an Arduino, there is no way that just running 1 extra dataline is going to be a problem. So convince me of the need for this project.
