controlling the mouse and keyboard with arduino and WII nunchuck
controlling the mouse with arduino
Using the arduino to control a game with wii nunchuck
code:
#include <Wire.h>
#include <ArduinoNunchuk.h>
#define BAUDRATE 19200
ArduinoNunchuk nunchuk = ArduinoNunchuk();
const int xAxis = A5;         // joystick X axis
const int yAxis = A4;         // joystick Y axis
// parameters for reading the joystick:
int range = 40;               // output range of X or Y movement
int responseDelay = 20;        // response delay of the mouse, in ms
int threshold = range/4;      // resting threshold
int center = range/2;         // resting position value
  Serial.begin(BAUDRATE);
  nunchuk.init();
 delay(20000);
  Mouse.begin();
   Keyboard.begin();
 nunchuk.update();
 //int xReading = readAxis(A5);
//  int yReading = readAxis(A4);
if (nunchuk.analogX<128)
   Keyboard.release('d');
 Keyboard.press('a');//left
 if (nunchuk.analogX>128)
    Keyboard.release('a');
 Keyboard.press('d');//left
 if (nunchuk.analogY>128)
    Keyboard.release('s');
 Keyboard.press('w');//left
  if (nunchuk.analogY<128)
    Keyboard.release('w');
 Keyboard.press('s');//left
   if (nunchuk.analogX==128)
  if (nunchuk.analogY==128)
 if (nunchuk.zButton)
    Keyboard.press('q');
    delay(10);
   Keyboard.release('q');
if (nunchuk.cButton)
    Keyboard.press('e');
    delay(10);
   Keyboard.release('e');
//Mouse.move(readAxisx(nunchuk.analogX), readAxisy(nunchuk.analogY), 0);
  reads an axis (0 or 1 for x or y) and scales the
 analog input range to a range from 0 to <range>
int readAxisx(int thisAxis) {
  // read the analog input:
  //int reading = analogRead(thisAxis);
  // map the reading from the analog input range to the output range:
 int  reading = map(thisAxis, 0, 255, 0, range);
  // if the output reading is outside from the
  // rest position threshold,  use it:
  int distance = reading - center;
  if (abs(distance) < threshold) {
    distance = 0;
  // return the distance for this axis:
  return distance;
int readAxisy(int thisAxis) {
 int  reading = map(thisAxis, 255, 0, 0, range);
    distance = 0;
  return distance;
