Hello i have problem t
To understand this problem, i want to save in a variable the date that i get from the function printLocalTime to use it after to create a file with the date on a SD card, but i don't know how i can do this on the following line :
char date= ('const char(&timeinfo, "%F")');
Here under i put the more complete code for better understanding thanks :
void printLocalTime(){
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("Failed to obtain time");
return;
Serial.print("Day of week: ");
Serial.println(&timeinfo, "%A");
Serial.print("Month: ");
Serial.println(&timeinfo, "%m");
Serial.print("Day of Month: ");
Serial.println(&timeinfo, "%d");
Serial.print("Year: ");
Serial.println(&timeinfo, "%Y");
Serial.print("Hour: ");
Serial.println(&timeinfo, "%H");
Serial.print("Minute: ");
Serial.println(&timeinfo, "%M");
Serial.print("Second: ");
Serial.println(&timeinfo, "%S");
Serial.print ("Il est exactement : ");
Serial.print(&timeinfo, "%X");
Serial.println (" Heures");
Serial.print("Nous sommes en : ");
Serial.println(&timeinfo, "%F");
char date= ('const char(&timeinfo, "%F")'); // OBJECTIF / Obtenir la date pour écriture sur carte SD
Serial.print ('date');
void loop(){
printLocalTime();//Appel de la fonction printLocalTime
appendFile(SD, "/hello.txt", "World!\n");
delay (1000);
appendFile(SD, "/hello.txt", "HH\n");
delay (1000);
appendFile(SD, "/hello.txt", "BB ");
delay (1000);
appendFile(SD, "/hellolol.txt", "BB ");
Serial.print (date);
Yours, or ours?
Can you explain this, please?
Please remember to use code tags when posting code.
Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
The code is not complete. Post the complete code or a minimal verifiable code that exhibits the fault.
Sorry i am french and i don' undersatnd your question Yours, or ours... what are you talking about ?
i have tried tu put the code between < > but i think i miss something sorry
There is a francophone forum.
What I meant was "Was the code for our (other forum users) better understanding, or for your better understanding? Because it didn't really help"
Ok i just learn the ctrl-t
ok the complete code
//Variable communication carte SD
#include "FS.h"
#include "SD.h"
//END
//Variable gestion WIFI, Date et Heure
#include <WiFi.h>
#include "time.h"
const char* ssid = "XXXXX";
const char* password = "XXXXXX";
const char* ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 3600;
String date;
//END
void removeDir(fs::FS &fs, const char * path) {
Serial.printf("Removing Dir: %s\n", path);
if (fs.rmdir(path)) {
Serial.println("Dir removed");
Serial.println("rmdir failed");
void appendFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Tentative ajout au fichier: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if (!file) {
Serial.println("Echec ouverture fichier pour ajout");
return;
if (file.print(message)) {
Serial.println("Ecriture fichier reussi");
Serial.println("Echec écriture fichier");
file.close();
void deleteFile(fs::FS &fs, const char * path) {
Serial.printf("Deleting file: %s\n", path);
if (fs.remove(path)) {
Serial.println("File deleted");
Serial.println("Delete failed");
// Connect to Wi-Fi
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("Tentative de connexion...");
Serial.println("");
Serial.println("WiFi connected.");
// Init and get the time
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
printLocalTime();
//disconnect WiFi as it's no longer needed
WiFi.disconnect(true);
WiFi.mode(WIFI_OFF);
if (!SD.begin(5)) {
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.print("SD Card Type: ");
if (cardType == CARD_MMC) {
Serial.println("MMC");
} else if (cardType == CARD_SD) {
Serial.println("SDSC");
} else if (cardType == CARD_SDHC) {
Serial.println("SDHC");
Serial.println("UNKNOWN");
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("SD Card Size: %lluMB\n", cardSize);
void printLocalTime() {
struct tm timeinfo;
if (!getLocalTime(&timeinfo)) {
return;
String date = (&timeinfo, "%F"); // OBJECTIF / Obtenir la date pour écriture sur carte SD
Serial.print ("%F");
delay (1000);
delay (1000);
delay (1000);
delay (1000);
How to use code tags (</>).
Please can you explain what this is?
Ha ok i understand now this is for our (other forum users) to help me on this matter. Thanks
What Arduino board are you using?
Are you sure that you want to broadcast your SSID and password to the world?
Hi thanks i just understand now how to post it proprely.
I print on serial port the day of the week with %A, this is coming from library time.h with a ntp server
This is ESP32 and thanks i modify my code to hide SSID and pass
You should answer the question posed by @ TheMemberFormerlyKnownAsAWOL.
Ok but this is working this, my problem is to pass the value to use it latter
Look
Is just silly - the single quotes make no sense.
Can you please just answer my earlier question?
Sorry i have problem to follow i answer allready no ?
No, you can't explain it?
