Convert ASCII value in binary value in Arduino IDE
Hi.
I've this piece of code that reads value from a BLE service CHARACTERISTIC_UUID (trasmitted from a BLE server to a BLE client, both running on two ESP32 boards) and write it on serial monitor:
 > #define SERVICE_UUID        "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
    #define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
class MyCallbacks: public BLECharacteristicCallbacks
    void onWrite(BLECharacteristic *pCharacteristic)
     std::string value = pCharacteristic->getValue();
      if (value.length() > 0) {
        Serial.println("*********");
        Serial.print("New value: ");
        for (int i = 0; i < value.length(); i++)
          Serial.print(value[i]);
If I look at the serial monitor I see , depending on the value trasmitted form the BLE client device, two ASCII character : null and what it represents the 1 (ON) value.
The question is:
how should I modify the code so that I may have in the serial monitor not the ASCII value but the binary (or decimal) value and can I treat it as such and use in the rest of the code (i.e. : in an if ... than statement)?
Any idea?
Thanks in advance.
Read each character into an array of chars as you receive it which, because of the null termination, will turn it into a C style string (lowercase s) that you can convert to a decimal value using the atoi() function for use in later comparisons or calculations
what do you really see ? the string "null" and the string "ON" or do you see "0" and "1" ? or something else?
Hi Jackson.
Thanks for your reply.
I'd like to have 0 and 1 as numbers not as alphanumerics characters.
Hi UKHeliBob.
Thanks for you reply.
May you provide an example on how to do this?
Thanks in advance.
Far from a complete example but it will show the principle that I was suggesting
byte charIndex = 0;         //index to the array
char buffer[10];            //buffer for characters read
bool inputComplete = false; //flag to indicate that input is complete
  while (Serial.available())      //read characters if available
    char inChar = Serial.read();  //read a character
    buffer[charIndex++] = inChar; //put it in the buffer
    if (inChar == '\0')           //if end of input
      inputComplete = true;       //flag complete
      break;                      //exit the while loop
  if (inputComplete)              //if input is complete
    int theNumber = atoi(buffer); //convert string to integer
    charIndex = 0;                //reset the array index
    //do whatever you need with theNumber value here
    inputComplete = false;        //ready for the next one
This is based on the code in this tutorial Serial input basics - updated
See example 2 in the linked topic
I don't think it's applicable here as the library offers a generic call to get the value that returns a string. (if I'm not mistaken)
I understand what you would want to see, but what do you get now when you do
what's in value??
on-off
change your function to be
     { Serial.print(value[i], DEC); Serial.write(' ');}
and share what you see in the Serial monitor
Now works better.
The issue is that the if statment don't recognize 0 e 1 and don't works as expected lightning ON and OFF the LED:
OK so you are getting binary data, not ASCII.
Try this
    if (value[0] == 0) {
      Serial.println("I GOT 0");
      Serial.println("I GOT 1");
  } else Serial.println("empty value");
Hi Jackson.
It works !
          digitalWrite(25,LOW);
          digitalWrite(25,HIGH);
The LED light ON and OFF like a charm.
Thanks
:slight_smile: have fun
