Converting a text into binary values
Hello everyone.
Im working on a project that implement the Direct Sequence Spread Spectrum using 2 Arduino Uno , a RF transmitter and a RF reciever.
I realized a basic RF communication between modules and now i have to implement the DSSS.For that i have to convert my message to binary.
For example , lets say the message is "Hi"
I declared my message like this:
const char * msg = "Hi";
I need to convert this message into his binary value which is "01001000 01101001 " and store it in another char.
I know you can convert it with "Serial.println(msg*, BIN);" but this option doesnt save the binary value.*
I need to save into binary format because after that , i have to make a XOR betweeen every 0 or 1 and another binari code like "10100"
Ex.
0 1 0 0 1 0 0 0 0 1 XOR
*10100 10100 10100 10100 10100 10100 10100 10100 10100 10100 *
I hope you can understand what am i asking and i hope anyone can help me with this
I'm not sure that I understand, but:
Is already a 16 bit binary value (excluding the null termination). I think you should explain exactely how the "binary value" is supposed to be used..
guturobert:
1.
01001000 (0x48) is (in fact) the ASCII code of H.
01101001 (0x69) is (in fact) the ASCII code of i.
2. To save the ASCII cdoes/values of Step-1 into two variables of byte data types, the following codes could be used:
char x = *msg;
byte x1 = x;               //x1 = 01001000
msg++;
x = *msg;
byte x2 = x;              //x2 = 01101001
3. To save the ASCII codes/values of Hi (01001000 01101001 = 0x4869) into single variable, the following codes could be executed:
const char *msg = "Hi";
int y1 = (int) * msg << 8; //y1 = 0100100000000000
msg++;
int y2 = (int) * msg; //y2 = 0000000001101001
int y = y1 | y2; //y = 0100100001101001
And the simpler way out would be:
uint16_t bin;
//Method 1
bin = *((uint16_t*)msg);
//Method 2
memcpy(&bin, msg, sizeof(bin));
But since OP does not answer, we do not know what he actually is trying to accomplish.
GolamMostafa:
1.
char x = *msg;
msg++;
x = *msg;
**3.** To save the ASCII codes/values of Hi (01001000 01101001 = 0x4869) into single variable, the following codes could be executed:
msg++;
This method works for a short text like "Hi".What i need is a method to convert longer text into binary format because i need to make a XOR operation between the string of 1 and 0 and a code called Pseudonoise.
What we are trying to tell you, is that text is already stored in binary format. Everything is. If there is some special kind of binary format that you need, you have to explain it better. I'm sure almost any contributor to this forum could show you how to 'xor' characters with a noise function, if you post some code examples and fully explain what you want to do.
If you mean store in another char array, the function to use is strcpy() or strncpy(). I don't see how you can copy it to a fixed length data type because strings are inherently variable length.
Welcome,
Here is an example: icwrAA - Online C++ Compiler & Debugging Tool - Ideone.com
Or, if you don't need to store these bits in a char array: CK9orf - Online C++ Compiler & Debugging Tool - Ideone.com
aarg:
Ok , im gonna try to be more explicit.I have a text that i need to convert every character of that text into his ASCII binary value(ex 01001000 is the ASCII code of H.). After that i have to store ASCII binary values because i need to make XOR between every bit of the converted string and a pseudonoise code of about 5 bits for example.
It still does not make any sense. Why would anyone do something as mad as converting a binary value into text in order to XOR it? And what is supposed to happen with the string after that? Converted back to binary? :open_mouth:
Look at this:
uint8_t H = 72; //ASCII = 'H', binary = 01001000
//XOR with 11111111 to flip all bits:
H ^⁼ 0b11111111;
Serial.println(H, DEC); //Prints 183
Serial.println(H, BIN); //Prints 10110111
If you would want to flip all bits in the string "ABC", then the sollution would be:
char ABC[] = "ABC";
for (int i = 0; i < strlen(ABC); i++) ABC[i] ^= 0b11111111;
This is as simple as it gets, no conversion needed.
What i need to implement is the DSSS concept in software on an arduino. You can check this short video and maybe you can understand what i have to do.
Im sorry if my explanation doesnt make sense but it s my first arduino project .
I'm not going to spend a lot of time to watch an educational video for something I do not need to know. What I did see was that I've told you exactely how to do what happens in the video in #8. If, for instance, you would want to transform 8 bytes with the (expanded) bits from one byte, that would look like this:
char transform_string[] = "12345678";
char bits = 0b10101010;
char bits_idx = 0;
for (char str_idx = 0; str_idx < strlen(transform_string); str_idx++)
  Serial.print("Transforming ");
  Serial.print((int)transform_string[str_idx], BIN);
  Serial.print(" with ");
  if (bits & (1 << bits_idx) != 0)
    Serial.print("1 = ");
    transform_string[str_idx] ^= 0b11111111;
    Serial.println((int)transform_string[str_idx], BIN);
    Serial.println("0 does nothing");
  if (++bits_idx == 8) bits_idx = 0; //Next bit
You might also want to check out bitRead which may be simpler for you to use.
I tried what you told me in #8 and after the conversion the output string was "??"
guix:
Welcome,
I think whis method worked , but now i have the following problem.How can i make a XOR between each bit and a pseudonoise ( a sequence of 0s and 1s ) ?
guturobert:
After an XOR of text, chances are very big that you end up with non-printable characters and printing will result in strange characters.
Just print each XOR'ed character's binary representation to see what the result of the XOR is.
