Correct pinout for TMC2209 stepper motor driver and Mega?
// https://github.com/janelia-arduino/TMC2209
#include <TMC2209.h>
// This example will not work on Arduino boards without HardwareSerial ports,
// such as the Uno, Nano, and Mini.
// See this reference for more details:
// https://www.arduino.cc/reference/en/language/functions/communication/serial/
HardwareSerial & serial_stream = Serial3;
const long SERIAL_BAUD_RATE = 115200;
const int DELAY = 3000;
// Instantiate TMC2209
TMC2209 stepper_driver;
  Serial.begin(SERIAL_BAUD_RATE);
  stepper_driver.setup(serial_stream);
  if (stepper_driver.isSetupAndCommunicating())
    Serial.println("Stepper driver is setup and communicating!");
    Serial.println("Try turning driver power off to see what happens.");
  else if (stepper_driver.isCommunicatingButNotSetup())
    Serial.println("Stepper driver is communicating but not setup!");
    Serial.println("Running setup again...");
    Serial.println("Stepper driver is not communicating!");
    Serial.println("Try turning driver power on to see what happens.");
  delay(DELAY);
TMC2209 ⟷ Mega
RX ⟷ TX3
GND ⟷ GND
VIO ⟷ 5V
EN ⟷ GND
I keep getting, "Stepper driver is not communicating!" So something isn't right. I swapped out drivers. I tested a program that moves the motor to confirm the driver works.
I'm not sure what "TX" does on the TMC2209 dev board/carrier. What works is connecting RX to RX and then putting a 1k resistor between the MCU's TX and RX pins (in this case, between the TX and RX of the Mega). The TX on the TMC2209 is left unattached.
