TMC2209 v2.1 UART problem
I have a tmc2209 driver. I think it is v2.1 as it has the tx and rx pins. I want to control 3 nema17s with 3 of these drivers. I have having problems as I want control them using UART. There are different suggestions everywhere. How to actually connect them? Below is my code just for one but it is not working. I will upload my schematic too. I am using this code, found on this forum but closed.
#include <TMCStepper.h>
#include <HardwareSerial.h>
#define STEP_PIN 12
#define SERIAL_PORT Serial
#define R_SENSE 0.11f
#define DRIVER_ADDRESS 0b00
#define MICROSTEPS 16
TMC2209Stepper driver(&SERIAL_PORT, R_SENSE, DRIVER_ADDRESS);
  SERIAL_PORT.begin(115200);      // INITIALIZE UART TMC2209
  Serial.println(F("Serial Initialized"));
  driver.begin();                // Initialize driver
  driver.toff(5);                 // Enables driver in software
  driver.rms_current(600);       // Set motor RMS current
  driver.microsteps(MICROSTEPS);
  driver.pwm_autoscale(true);    // Needed for stealthChop
  driver.en_spreadCycle(false);   // false = StealthChop / true = SpreadCycle
  driver.shaft(false);
  Serial.print(F("microsteps: "));   Serial.println(driver.microsteps());
  Serial.print(F("current: "));   Serial.println(driver.rms_current());
  digitalWrite(STEP_PIN, HIGH);
  delay(3.6);
  digitalWrite(STEP_PIN, LOW);
  delay(3.6);
What is the source of power for the stepper motors?
Where are those other suggestions? The only one that matters is the data sheet for the device. It suggests using RS-485 electrical connection. So, use a RS-485 adapter on the Arduino end and direct to the TMC2209 on the other end. Let us know if that works.
it is a 12V DC
Actually it worked using this thread here:TMC2209 and ESP32 - UART Wiring - #8 by murdock_85
..but they are having other problem..so for now i think i'm good until further notice
