Bought the LED strip from a Chinese seller, not much information there (except the strip is running on 12V) and "LED type: SMD 5050".
So I suppose: http://e-radionica.com/productdata/RGB5050LED.pdf
I bought without power supply so I have to find/buy one if I know how much the controllers + LED will need.
I believe the WS2811 is a driver chip, so you don't need any transistors if you are driving LEDs with it.
That's usually a very-bad start...
If you buy stuff from reputable suppliers you can get a manufacturer's part number and/or datasheet. Sites like Adafruit and SparkFun usually have that plus additional information.
Sometimes you can get-away with no specs or datasheet if you really know what you are doing or unless you are a really good "hacker" and good at "figuring things out" and "making it work", but there are always risks with that.
I have a 12V/2A power supply from another (shorter) all-in-one LED strip, do you guys think that 2A is enough for 150 LED? (i dont want to fry the supply)
And how do I measure the current drawn when all LEDs are white when I cannot talk to the controllers? Whithout data input the LEDs remain off.
