So I've ordered a Freescale MPX5050GP pressure sensor which supposedly can be connected to the arduino without any amplifier. I previously used a MPX12GP which did need an amplifier.
Im trying to wire the sensor to the arduino, and the VCC, GND and Vout are pretty obvious i guess, I just am too inexperienced with datasheets to deduce how to connect the rest of the pins.. theres V1, V2 and Vex, but I am at a loss what to do with those..
I've googled for some wiring schematics or projects where people explain how to wire the sensor to the arduino but to no avail..
I hope one of you guys can help me out!
Thanks in advance.
Edit. I just found a similar sensor wiring schematic, which says to only wire the first 3 pins ( Vout, GND, VCC) basically.. But what are the other 3 for then? Calibration or something?
In the datasheet they write in capitals that the other pins are "NO CONNECTS". You may not connect those to anything!
Perhaps they are used during manufacturing or calibrating the sensor, I don't know.
Ok, so this topic is way old. But I have an MPX5050 and an arduino on my desk (6-sip format). I have an LCD readout of the pressure and an LED that lights up when it is over 26 psi.
The circuit is simple. Pin 1 (Vout) goes to an analog in (A0 for me). Pin 2 to ground. Pin 3 to Vcc (5 V). The other pins are just floating there, not connected to anything.
float voltage = (float) 5*sensorValue/1023 - .15; // voltage at Arduino pin. Range is 5V, 10 bits.
This isn't quite right, meaning it isn't calibrated, but it gives me a good reading. divide by 68.9476 for psi
I apologize for posting to such an old post, but I just ordered 10 more of these sensors for a hemodialysis test project and found this in my search.
