Hi Guys,
I am bit stuck, I am unable to connect to my FONA 800 Shield. Below is my code
This is an example for our Adafruit FONA Cellular Module
since the FONA 3G does not do auto-baud very well, this demo
fixes the baud rate to 4800 from the default 115200
Designed specifically to work with the Adafruit FONA 3G
----> http://www.adafruit.com/products/2691
----> http://www.adafruit.com/products/2687
These cellular modules use TTL Serial to communicate, 2 pins are
required to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// this is a large buffer for replies
char replybuffer[255];
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
// HardwareSerial *fonaSerial = new HardwareSerial(2);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
while (!Serial);
Serial.println(F("FONA set baudrate"));
Serial.println(F("First trying 115200 baud"));
// start at 115200 baud
fonaSerial->begin(115200);
fona.begin(*fonaSerial);
// send the command to reset the baud rate to 4800
fona.setBaudrate(4800);
// restart with 4800 baud
fonaSerial->begin(4800);
Serial.println(F("Initializing @ 4800 baud..."));
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
Serial.println(F("FONA is OK"));
// Print module IMEI number.
char imei[15] = {0}; // MUST use a 16 character buffer for IMEI!
uint8_t imeiLen = fona.getIMEI(imei);
if (imeiLen > 0) {
Serial.print("Module IMEI: "); Serial.println(imei);
I have also attached screenshot of my arduino + fona 800 shield setup and the screenshot of the message that i get in serial monitor. Please let me know what i am doing wrong
