Counter with input from keypad
Hi there... I'm new to Arduino programming. I'm building a counter with keypad to enter value. After searching the internet, I found sketch in this forum and it seems that this sketc is suitable for me. Here is my code, completely:
#include <Key.h>
#include <Keypad.h>
#include <LCD.h>
#include <Wire.h>
#include <Keyboard.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
long startTime;  // start time for stop watch
long inputTime;  // entered time
long remainingTime;  // remaining time
const int NRow = 2;  // no of LCD rows
const int NCol = 16;  // no of LCD columns
const byte ROWS = 4;  // four rows of keypad
const byte COLS = 4;  // four columns of keypad, replace with 3 if 3column is used
char keys[ROWS][COLS] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'.', '0', '#', 'D'}
byte rowPins[ROWS] = {11, 10, 9, 8};  //connect to the row pinouts of the keypad //four rows
byte colPins[COLS] = {7, 6, 5, 4};  //connect to the column pinouts of the keypad //four column
Keypad keypad = Keypad (makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  lcd.begin(16, 2);  // intialise the LCD.
  inputTime = GetNumber();
    startTime = millis(); // store the start time
    remainingTime = (inputTime - startTime); // sisa waktu berjalan
    if (remainingTime < 0)
      lcd.setCursor(0, 1);
      lcd.print(inputTime - inputTime); // display input time
      lcd.setCursor (12, 1);
      lcd.print("STOP");
    if (remainingTime > 0)
      lcd.print(remainingTime); // countdown function
      lcd.print("RUN!");
    // Digit manipulation
    if (remainingTime < 100000)
      lcd.setCursor(5, 1);
      lcd.print(" ");
    if (remainingTime < 10000)
      lcd.setCursor(4, 1);
      lcd.print(" ");
    if (remainingTime < 1000)
      lcd.setCursor(3, 1);
      lcd.print(" ");
    if (remainingTime < 100)
      lcd.setCursor(2, 1);
      lcd.print(" ");
    if (remainingTime < 10)
      lcd.setCursor(1, 1);
      lcd.print(" ");
int GetNumber() // adopted from https://forum.arduino.cc/index.php?topic=57627.0
  int num = 0;
  char key = keypad.getKey();
  while (key != 'D') //  Pressing "D" to run the program
    switch (key)
      case NO_KEY:
      case '0': case '1': case '2': case '3': case '4':
      case '5': case '6': case '7': case '8': case '9':
      case '.':
        lcd.print(key);
        num = num * 10 + (key - '0');
      case 'A': // Select mSec mode.
        num = 0;
        lcd.setCursor(0, 0);
        lcd.print("mSec");
        // mSec();
        lcd.clear();
      case 'B': // Select Sec. mode.
        num = 0;
        lcd.print("Sec.");
        //tSec();
        lcd.clear();
      case 'C': // Test solenoid.
        num = 0;
        lcd.clear();
        //to be done
      case '#': // Clear screen.
        num = 0;
        lcd.clear();
  return num;
But, it doesn't work with my counter: When I press "D" button to start, the counter is not counting. Pressing "D" change the counter value. Next counting attempt (after pressing previous "D") cause the entry line goes to another row.
I am expecting that I can enter some values. The counter starts counting when I press "D" and stops when the counter show "0" then ready for the next counting process.
I need somebody to help fixing my problem. Any help is appreciated. Thanks in advance.
Look at what happens in your code. The first thing that loop() does is call GetNumber() which blocks until you enter the 'D', in which case it returns.
Then, you have useless curly braces around the rest of the code. That code calculates the remaining time, in some bizarre fashion, based on how long the Arduino has been running. It then displays some data on the LCD. The loop() function ends, and gets called again, where it once more waits for you to enter a time and press the 'D' key.
You need a global boolean, needToGetTime, initialized to true. GetNumber() needs to be called only when that flag is true. It needs to set the flag to false.
When the entered time has elapsed, the code needs to set the flag to true again.
AND, you need to calculate remainingTime correctly, by ADDING the time to diddle to now, not by subtracting.
PaulS:
Thank you very much for your response Sir. I try several different way but I'm stuck now. Kindly would you please show me clearly how to fix this. I'm sorry for being stupid.
Can't help with stupid.
Won't help with won't even try.
