Determining the gravity acceleration via damping spring is one of the fundamental physics experiments. Because students can not start stopwatch on time and also detecting the exact moment of transition of the the spring at a given point is difficult, often quite unexpected results of this trial will be appeared.
We decided to find a way to count the number of (e.g 10) swings, with the help of an eye-sensor.
That is:
Connecting to an electronic stopwatch
Connecting to an optical sensor
Programming to calculate the 10 swings
Such a thing is possible with arduino? Is it done before? sth similar will be a help!
Let the spring hang from a load cell and the Arduino measuring the weight 10 to 100 times a second.
Can something be attached to the spring ? or will the weight have influence ? Something can be connected that bounces the signal of an ultrasonic or IR distance sensor. Or an accelerometer directly connected to the spring.
Use an IR distance sensor. I think that is the easiest solution and it will work.
There might be many other ways (load cell, magnet + hall, ultrasonic distance, accelerometer, visual with webcam + software, IR gate), but they are not better.
You have to find one that has a range that you need and works with 5V.
So all you need is an Arduino Uno and such a sensor (and a 7...7.5...12V power supply). Connect the Arduino Uno to a computer, make the code for it, and maybe you have to attach a piece of white paper to the bottom of the weights.
Have a look at the datasheet, so you know what the output graph is according to the distance.
The Power Supply can be a small switching power supply. It might be needed for more accurate data. The Arduino uses the 5V by default for reference to measure an analog voltage. When the Arduino Uno is powered via the usb cable, the 5V could be 4.6V, and that makes the data inaccurate. You can avoid that by powering the Arduino Uno with a power supply to the barrel jack.
