This one has been a tough one for me to get my head around. Im hoping i could get some help figuring out how to setup a matrix to scan a piano keyboard for MIDI notes. Im using a Teensy 2.0++ a 74LS42 to set the 8 column outputs low one at a time and a 4069 to invert the signal going to the rows (Those chips cant be changed for alternatives) I know i could write 200 if statements to make it work but i know theres a better smarter way of doing this. The main loop is just my test ground trying to get one column to work so dont judge it too much
Any help would be greatly appreciated
//ROWS/////////////////////////////////////////////////////////////////////////////////////////////////////////
//SCAN MATRIX INPUT PINS
const int row0 = 38;
const int row1 = 39;
const int row2 = 40;
const int row3 = 41;
const int row4 = 42;
const int row5 = 43;
const int row6 = 44;
const int row7 = 45;
//COLS/////////////////////////////////////////////////////////////////////////////////////////////////////////
//SCAN MATRIX OUTPUT VALUES
int col = 0;
int n = 0;
//SCAN MATRIX OUTPUT PINS
// The 74LS42 (IC58) link which has four pins
const int pinA = 13;
const int pinB = 14;
const int pinC = 15;
const int pinD = 16;
//MIDI
uint8_t keyToMidiMap[64];
int noteVelocity = 127;
//BOOLEAN LOGIC TO TELL IF KEY WAS ALREADY PRESSED
boolean keyPressed[64];
// The 74LS42 (IC58) shift up to next column
void scanColumn() {
col++;
if (col > 8) col = 0;
Serial.println (col);
digitalWrite(pinA, col & 1);
digitalWrite(pinB, col & 2);
digitalWrite(pinC, col & 4);
digitalWrite(pinD, col & 8);
//Serial.println (col);
// Map scan matrix buttons/keys to actual Midi note number. Lowest num 41 corresponds to F MIDI note.
keyToMidiMap[0] = 48;
keyToMidiMap[1] = 41;
keyToMidiMap[2] = 42;
keyToMidiMap[3] = 43;
keyToMidiMap[4] = 44;
keyToMidiMap[5] = 45;
keyToMidiMap[6] = 46;
keyToMidiMap[7] = 47;
keyToMidiMap[8] = 56;
keyToMidiMap[1 + 8] = 49;
keyToMidiMap[2 + 8] = 50;
keyToMidiMap[3 + 8] = 51;
keyToMidiMap[4 + 8] = 52;
keyToMidiMap[5 + 8] = 53;
keyToMidiMap[6 + 8] = 54;
keyToMidiMap[7 + 8] = 55;
keyToMidiMap[16] = 64;
keyToMidiMap[1 + 16] = 57;
keyToMidiMap[2 + 16] = 58;
keyToMidiMap[3 + 16] = 59;
keyToMidiMap[4 + 16] = 60;
keyToMidiMap[5 + 16] = 61;
keyToMidiMap[6 + 16] = 62;
keyToMidiMap[7 + 16] = 63;
keyToMidiMap[24] = 72;
keyToMidiMap[1 + 24] = 65;
keyToMidiMap[2 + 24] = 66;
keyToMidiMap[3 + 24] = 67;
keyToMidiMap[4 + 24] = 68;
keyToMidiMap[5 + 24] = 69;
keyToMidiMap[6 + 24] = 70;
keyToMidiMap[7 + 24] = 71;
keyToMidiMap[32] = 80;
keyToMidiMap[1 + 32] = 73;
keyToMidiMap[2 + 32] = 74;
keyToMidiMap[3 + 32] = 75;
keyToMidiMap[4 + 32] = 76;
keyToMidiMap[5 + 32] = 77;
keyToMidiMap[6 + 32] = 78;
keyToMidiMap[7 + 32] = 79;
keyToMidiMap[40] = 88;
keyToMidiMap[1 + 40] = 81;
keyToMidiMap[2 + 40] = 82;
keyToMidiMap[3 + 40] = 83;
keyToMidiMap[4 + 40] = 84;
keyToMidiMap[5 + 40] = 85;
keyToMidiMap[6 + 40] = 86;
keyToMidiMap[7 + 40] = 87;
keyToMidiMap[48] = 96;
keyToMidiMap[1 + 48] = 89;
keyToMidiMap[2 + 48] = 90;
keyToMidiMap[3 + 48] = 91;
keyToMidiMap[4 + 48] = 92;
keyToMidiMap[5 + 48] = 93;
keyToMidiMap[6 + 48] = 94;
keyToMidiMap[7 + 48] = 95;
keyToMidiMap[56] = 104;
keyToMidiMap[1 + 56] = 97;
keyToMidiMap[2 + 56] = 98;
keyToMidiMap[3 + 56] = 99;
keyToMidiMap[4 + 56] = 100;
keyToMidiMap[5 + 56] = 101;
keyToMidiMap[6 + 56] = 102;
keyToMidiMap[7 + 56] = 103;
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(row0, INPUT);
pinMode(row1, INPUT);
pinMode(row2, INPUT);
pinMode(row3, INPUT);
pinMode(row4, INPUT);
pinMode(row5, INPUT);
pinMode(row6, INPUT);
pinMode(row7, INPUT);
Serial.begin(31250);
scanColumn();
if (col <= 7) {
// check if any keys were pressed - rows will have HIGH output in this case corresponding
int groupValue0 = digitalRead(row0);
int groupValue1 = digitalRead(row1);
int groupValue2 = digitalRead(row2);
int groupValue3 = digitalRead(row3);
int groupValue4 = digitalRead(row4);
int groupValue5 = digitalRead(row5);
int groupValue6 = digitalRead(row6);
int groupValue7 = digitalRead(row7);
// process if any combination of keys pressed
if (col == 0 && !keyPressed[col]) {
keyPressed[col] = true;
noteOn(0x91, keyToMidiMap[col], noteVelocity);
// process if any combination of keys released
if (col != 0 && keyPressed[col]) {
keyPressed[col] = false;
noteOn(0x91, keyToMidiMap[col], 0);
//Scan for Transpose/ARP and key assign/ ARP range/ Arp on/ Keytrans
if (col == 8){
digitalWrite( 6, HIGH );
delay(50);
digitalWrite( 6, LOW );
Serial.println (keyPressed[col]);
void noteOn(int cmd, int pitch, int velocity) {
//Serial.println (groupValue);
//Serial.print("CMD: ");
//Serial.println(cmd);
//Serial.print("PITCH:");
//Serial.println(pitch);
//Serial.print("VELO:");
//Serial.println(velocity);
