Cunsumtion of LoRa module is 1.2 mA in deep-sleep mode
Hello.
I'm working on a project, using a ESP32 Lora board, where I need to optimise the energy cunsumption (the board will be stored outside, connected to my hives).
On the following discussion (Cunsumtion of LoRa module is 1.2 mA in deep-sleep mode - #12 by srnet), there are recommandations to setup a pullup resistance (that apparently solved the problem),
And therefore I have some questions as I would like to do the same :
  1. Could somebody tell me exactly what it means : how to setup a pullup resistor ? (what needs to be done)... I don't know.
  2. I'm using a "integrated ESP32 Lora" board : does it make sense to do that with the board or do I need to use separated board (ESP32 and a Lora board seperatelly) ?
Thanks for your help. Best regards.
I moved your topic to an appropriate forum category @essarts-le-roi.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Post #10 has a descrption of setting up a pullup resistor for NSS pin.
"You connect one end of the resistor to the NSS pin and connect the other end to 3.3V. A 10K resistor will do."
Hello. Thanks for your answer. But.... and it was the purpose of my other question, is that may be the board I'm using is not OK for optimising the energy consumption. There is no NSS pin available.....
For your info, here is the code I have writte trying to optimise the Consumption
:slight_smile:
saisissez ou collez du code ici
  file = ESP32 Ruch connectee - Remote - IDE -20240xxx---
  Sketch pour Ruche connectee / LORA & OLED / Sondes poid HX711
  P2P Lora - scenario remote / Emission only
  PASSAGE EN HIBERNATION
  https://m1cr0lab-esp32.github.io/sleep-modes/hibernation-mode/
Projet ruche connectée - HX711 04 Avril 2023
Pour ne pas s'embarasser avec la tare : le calibrage de la balance de JN est codée ds le pgrm
// *** PARAMETRAGE * TO BE UPDATED/DEBUT *********************
// 1) Numero de la balance
const int numero_de_la_balance_int = 1;
// 2) carte utilisée
// #define ESP32-TTGO
#define ESP32-LILYGOT31.6.1
// 3) Données de l'envoi des mesures
// #define TIME_TO_SLEEP  duree_entre_envoi_mn*60        /* Time ESP32 will go to sleep (in seconds) */
int   duree_entre_envoi_mn = 20; // Duree entre envoi en mn = duree du sleep
// 4) numero de la balance
// #define BALANCE_1 // Balance JAUNE Métal
// #define BALANCE_2 // ALU PROFILE - lourde
#define BALANCE_RANDOM
//*** Autres variable
// 5) BW Lora
#define BANDWITH433
// #define BANDWITH868
// 6) DEBUG pas DEBUG
// #define DEBUG // on est en compilation pour du DEBUG. Sinon, on minimise donc la consommation
// 7) Outil de compilation
// #define COMPILATION CLOUD IoT // Si pas sélectionné, alors complilation IDE
//*** CONTEXT/CONSTANTE/FIN *************************************************************
// Calibrage balance
float Balance_random_facteur_de_calibration = 0;
float Balance_random_decallage_poids = 0;
float Balance_1_facteur_de_calibration = 29.4025;
float Balance_1_decallage_poids = 2844.285;
float Balance_2_facteur_de_calibration = 21.84;
float Balance_2_decallage_poids = 4270;
float Balance_3_facteur_de_calibration = 0;
float Balance_3_decallage_poids = 0;
float Balance_4_facteur_de_calibration = 0;
float Balance_4_decallage_poids = 0;
float Balance_5_facteur_de_calibration = 0;
float Balance_5_decallage_poids = 0;
float Balance_6_facteur_de_calibration = 0;
float Balance_6_decallage_poids = 0;
float Balance_7_facteur_de_calibration = 0;
float Balance_7_decallage_poids = 0;
float Balance_8_facteur_de_calibration = 0;
float Balance_8_decallage_poids = 0;
float Balance_9_facteur_de_calibration = 0;
float Balance_9_decallage_poids = 0;
float Balance_10_facteur_de_calibration = 0;
float Balance_10_decallage_poids = 0;
const byte Header1 = 0x06; // pour reconnaire la trame Ruche
const byte Header2 = 0x07; // pour reconnaire la trame Ruche
const byte Version_du_protocole_lora = 0x01;
const byte Adresse_gway = 0xFE; 		// address of the remote gateway
// Librairies pour Lora
#include <SPI.h>
#include <LoRa.h>
//Libraries pour OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#ifdef BANDWITH433
#define BAND 433E6
#endif
#ifdef BANDWITH868
#define BAND 868E6
#endif
// version TTGO ESP32
#ifdef ESP32-TTGO
//define the pins used by the LoRa transceiver module
#define RADIO_SCLK_PIN 5
#define RADIO_MISO_PIN 19
#define RADIO_MOSI_PIN 27
#define RADIO_CS_PIN 18
#define RADIO_RST_PIN 14 // Changed CH - OLD = 16; NEW = 14
#define RADIO_DIO0_PIN 26
#define RADIO_DIO1_PIN 33
#define DIO2 32
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#endif
// version 2 ESP32 LillyGo [from Bidouilleurs https://www.youtube.com/watch?v=o8Pd-hZDYwc]
# ifdef ESP32-LILYGOT31.6.1
//OLED pins LiLYGo / T3 version 1.6.1
// #define OLED_RST 2   // n'est peut ĂŞtre pas le 2 mais e, tout cas, pas le 16
#define OLED_SDA                     21
#define OLED_SCL                     22
#define UNUSE_PIN                   (0)
#define OLED_RST                    UNUSE_PIN
#define RADIO_RST_PIN               23
#define RADIO_BUSY_PIN              32
#define SDCARD_MOSI                 15
#define SDCARD_MISO                 2
#define SDCARD_SCLK                 14
#define SDCARD_CS                   13
#define BOARD_LED                   25
#define LED_ON                      HIGH
#define ADC_PIN                     35
#define HAS_SDCARD
#define HAS_DISPLAY
#endif
// Sonde HX711
// Balance
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 15;
const int LOADCELL_SCK_PIN = 12;
int alimentation_de_la_balance = 13;
#ifdef BALANCE_RANDOM
float facteur_de_calibration = Balance_random_facteur_de_calibration;
float decallage_poids = Balance_random_decallage_poids;
#endif
#ifdef BALANCE_1
facteur_de_calibration = Balance_1_facteur_de_calibration;
decallage_poids = Balance_1_decallage_poids;
#endif
#ifdef BALANCE_2
facteur_de_calibration = Balance_2_facteur_de_calibration;
decallage_poids = Balance_2_decallage_poids;
#endif
#ifdef BALANCE_3
facteur_de_calibration = Balance_3_facteur_de_calibration;
decallage_poids = Balance_3_decallage_poids;
#endif
#ifdef BALANCE_4
facteur_de_calibration = Balance_4_facteur_de_calibration;
decallage_poids = Balance_4_decallage_poids;
#endif
#ifdef BALANCE_5
facteur_de_calibration = Balance_5_facteur_de_calibration;
decallage_poids = Balance_5_decallage_poids;
#endif
#ifdef BALANCE_6
facteur_de_calibration = Balance_6_facteur_de_calibration;
decallage_poids = Balance_6_decallage_poids;
#endif
#ifdef BALANCE_7
facteur_de_calibration = Balance_7_facteur_de_calibration;
decallage_poids = Balance_7_decallage_poids;
#endif
#ifdef BALANCE_8
facteur_de_calibration = Balance_8_facteur_de_calibration;
decallage_poids = Balance_8_decallage_poids;
#endif
#ifdef BALANCE_9
facteur_de_calibration = Balance_9_facteur_de_calibration;
decallage_poids = Balance_9_decallage_poids;
#endif
#ifdef BALANCE_10
facteur_de_calibration = Balance_10_facteur_de_calibration;
decallage_poids = Balance_10_decallage_poids;
#endif
HX711 scale;
// Balance Parametre Christophe H.
float valeur_de_lecture_brute = 0;
float poids_de_lobjet = 0;
// Données des mesures
const unsigned long duree_entre_envoi_secondes = duree_entre_envoi_mn*60;	// en s - durée avant chaque envoi
// Données du sleep mode
#define uS_TO_S_FACTOR 1000000  /* Conversion factor for micro seconds to seconds */
// RTC_DATA_ATTR int bootCount = 0; // The last variable we declare is bootCount, which is a counter for how many times the ESP32 has booted.
// Structure Lora
struct __attribute__((packed)) MessageLora {
  byte header1;  // pour reconnaitre trame
  byte header2;  // pour reconnaitre trame
  byte version;  // pour évolutions future
  byte emetteur;
  byte destinataire;
  byte relais; // enregistre les relais potentiels
  int numero_du_message;
  float donnee1; // Poid
  float donnee2; // pour évolution future
  boolean donnee3; // pour évolution future
  boolean donnee4; // pour évolution
  float checksum; // pour évolution future
  char text[30]; // pour évolution future
MessageLora messageLora;
// Donnees pour traitement Lora des infos reçues
byte header1_du_message;
byte header2_du_message;
byte version_du_message;
byte emetteur_du_message;
byte destinataire_du_message;
byte relais_du_message;
float donnee1_du_message;
float donnee2_du_message;
boolean donnee3_du_message;
boolean donnee4_du_message;
float checksum_du_message;
char text_du_message[30];
// Autres données de traitement
byte Adresse_device = numero_de_la_balance_int;		// address of this device
const int debut_numero_du_message = numero_de_la_balance_int * 100;
unsigned long currentTime = 0;
int etat_automate = 0;
int message_status = 0;
int message_ERR = 0;
int n, t;
int numero_device = 0;
int taille_du_message;
int delay_de_temporisation_pour_fonction_delay_ms = 3000;
// constante OLED
const int increment_ligne = 8;
const int debut_ligne_status = 0;
const int debut_ligne_received = increment_ligne * 2;
const int debut_ligne_sent = increment_ligne * 5;
// Initialisation ecran OLED
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
void setup()  {
#ifdef DEBUG
  // Initialize serial and wait for port to open
  // This delay gives the chance to wait for a Serial Monitor without blocking if  none is found
  delay(delay_de_temporisation_pour_fonction_delay_ms);
  //  ++bootCount;  // Add 1 to the current value of bootCount - it is recorded
  // Defined in thingProperties.h
  // Enlever pour tests - A REMETTRE
  // initProperties();
 //reset OLED display via software
  pinMode(OLED_RST, OUTPUT);
  digitalWrite(OLED_RST, LOW);
  delay(20);
  digitalWrite(OLED_RST, HIGH);
  //initialize OLED
  Wire.begin(OLED_SDA, OLED_SCL);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false))
    // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  Serial.println("Lancement - etat[" + String(etat_automate) +"]");
  // displayOLED(1, 0, 0, debut_ligne_status + increment_ligne*0, 1, "Start Rem. [" + String(bootCount) + "]boot",1);
  displayOLED(1, 0, 0, debut_ligne_status + increment_ligne*0, 1, "Start Rem. [" + String(Adresse_device) + "]",1);
#endif
  // override the default CS, reset, and  IRQ pins (optional)
  //SPI LoRa pins
  SPI.begin(RADIO_SCLK_PIN, RADIO_MISO_PIN, RADIO_MOSI_PIN, RADIO_CS_PIN);
  //setup LoRa transceiver module
  LoRa.setPins(RADIO_CS_PIN, RADIO_RST_PIN, RADIO_DIO0_PIN);
  if (!LoRa.begin(BAND)) {             // initialize ratio for Europe
#ifdef DEBUG
    Serial.println("LoRa init failed. Check your connections.");
#endif
    while  (true);                       // if failed, do nothing
#ifdef DEBUG
  // displayOLED(1, 0, 0, debut_ligne_status + increment_ligne*0, 1, "Rem[" + String(Adresse_device) + "]/LoRa OK/Boot " + String(++bootCount),1);
#endif
  LoRa.setSpreadingFactor(12);
  LoRa.setSignalBandwidth(62.5E3);
  LoRa.setCodingRate4(5); //min 5- max 8
#ifdef DEBUG
  // Balance - NOTE : on ne veut pas tarer à chaque fois car on ne peut pas déplacer la ruche à chaque reboot.
  // les paramètres de calcul du poids sont donc "hardcodé". Ils ont été calculé précédement. Les paramètres sont propres à chaque balance
  Serial.println("HX711 Demo");
  Serial.println("Initializing the scale");
#endif
  pinMode(alimentation_de_la_balance, OUTPUT);
  digitalWrite(alimentation_de_la_balance, HIGH);
  scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
  scale.tare();
void  loop() {
  currentTime = millis();
  lecture_des_mesures();
  // Preparation & envoi du message
  preparation_du_message();
  ecriture_du_message();
  sendMessage();
  // nettoyage_structure_lora();
  delay(delay_de_temporisation_pour_fonction_delay_ms); // pour s'assurer que le message est bien parti
#ifdef DEBUG
  displayOLED(0, 1, 0, debut_ligne_status + increment_ligne*0, 1, "Rem[" + String(Adresse_device) +"]/Sleep",1);
  displayOLED(0, 1, 0, debut_ligne_status + increment_ligne*1, 1, "Duree = " + String(duree_entre_envoi_secondes) + "s/" + String(duree_entre_envoi_secondes/60) + "mn" ,1);
  // Mise en mode veille
  Serial.println("Passage en mode HIBERNATION " + String(duree_entre_envoi_secondes) +"s");
#endif
  LoRa.sleep();
  //u8g2->sleepOn();
  SPI.end();
  // SDSPI.end();
  pinMode(RADIO_CS_PIN, INPUT);
  pinMode(RADIO_RST_PIN, INPUT);
  pinMode(RADIO_DIO0_PIN, INPUT);
  pinMode(OLED_SDA, INPUT);
  pinMode(OLED_SCL, INPUT);
  pinMode(OLED_RST, INPUT);
  pinMode(RADIO_SCLK_PIN, INPUT);
  pinMode(RADIO_MISO_PIN, INPUT);
  pinMode(RADIO_MOSI_PIN, INPUT);
  pinMode(SDCARD_MOSI, INPUT);
  pinMode(SDCARD_MISO, INPUT);
  pinMode(SDCARD_SCLK, INPUT);
  pinMode(SDCARD_CS, INPUT);
  pinMode(BOARD_LED, INPUT);
  pinMode(ADC_PIN, INPUT);
  // Specifique au mode hibernation / C'est un paramétrage du DeepSleep pour désactiver la mémoire
  esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH,   ESP_PD_OPTION_OFF);
  esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_SLOW_MEM, ESP_PD_OPTION_OFF);
  esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_FAST_MEM, ESP_PD_OPTION_OFF);
  esp_sleep_pd_config(ESP_PD_DOMAIN_XTAL,         ESP_PD_OPTION_OFF);
  // Passage en deep_sleep - Set up timer as the wake up source and set sleep duration
  esp_sleep_enable_timer_wakeup(duree_entre_envoi_secondes * uS_TO_S_FACTOR);
  Serial.flush();  // Wait for the transmission of outgoing serial data to complete.
  esp_deep_sleep_start();
void lecture_des_mesures(){
// calculs
  valeur_de_lecture_brute = scale.read_average(20);
  poids_de_lobjet = valeur_de_lecture_brute/facteur_de_calibration - decallage_poids;
  if (poids_de_lobjet < 0) // pour corriger les erreurs de calibrage de balance - on met 1g
    poids_de_lobjet = 1;
  // TEST - LECTURE RANDOM
  poids_de_lobjet = random(10, 80);
#endif
#ifdef DEBUG
  Serial.println("Mesure brute = " + String(valeur_de_lecture_brute) + " / " + String(poids_de_lobjet/1000) + "kg");
  displayOLED(0, 1, 0, debut_ligne_sent + increment_ligne * 0, 1, "Poids = " + String(poids_de_lobjet) + "g" ,1);
#endif
  scale.power_down();			        // put the ADC in sleep mode
  digitalWrite(alimentation_de_la_balance, LOW);
void preparation_du_message()
  header1_du_message = Header1;
  header2_du_message = Header2;
  version_du_message = Version_du_protocole_lora;
  emetteur_du_message = Adresse_device;
  destinataire_du_message = Adresse_gway;
  relais_du_message = 0x00;
  numero_du_message = random(debut_numero_du_message, debut_numero_du_message+99);
  donnee1_du_message = poids_de_lobjet;
  donnee2_du_message = 0;
  donnee3_du_message = 0;
  donnee4_du_message = 0;
  checksum_du_message = numero_du_message + donnee1_du_message + donnee2_du_message;
  for (n = 0; n < 30; n++)
    text_du_message[n] = ' ';
!!   FONCTIONS COMMUNES AUX DEVICES - SYSTEMES, RELAIS, GATEWAY
!!   A recopier
void onReceive(int  packetSize)
  if (packetSize == 0) {
    message_status = 0;
    return;          // if there's no packet,  return
  taille_du_message = packetSize;
#ifdef DEBUG
  Serial.println("Message recu");
  Serial.println("Lora receive RSSI = " + String(LoRa.packetRssi()) + " / packet size " + String(packetSize));
  displayOLED(0, 1, 0, debut_ligne_received + increment_ligne * 0, 1, "RSSI = " + String(LoRa.packetRssi()),1);
#endif
  message_status = 1;
    message_status = 0;
#ifdef DEBUG
#endif
  message_status = 1;
void nettoyage_structure_lora()
  messageLora.header1 = 0x00;
  messageLora.header2 = 0x00;
  messageLora.version = 0x00;
  messageLora.emetteur = 0x00;
  messageLora.destinataire = 0x00;
  messageLora.relais = 0x00;
  messageLora.numero_du_message = 0;
  messageLora.donnee1 = 0;
  messageLora.donnee2 = 0;
  messageLora.donnee3 = false;
  messageLora.donnee4 = false;
  messageLora.checksum = 0;
    messageLora.text[n] = ' ';
void ecriture_du_message()
  messageLora.header1 = header1_du_message;
  messageLora.header2 = header2_du_message;
  messageLora.version = version_du_message;
  messageLora.emetteur = emetteur_du_message;
  messageLora.destinataire = destinataire_du_message;
 messageLora.relais = relais_du_message;
  messageLora.numero_du_message = numero_du_message;
  messageLora.donnee1 = donnee1_du_message;
  messageLora.donnee2 = donnee2_du_message;
  messageLora.donnee3 = donnee3_du_message;
  messageLora.donnee4 = donnee4_du_message;
  messageLora.checksum = checksum_du_message;
  *messageLora.text =   *text_du_message;
void lecture_du_message()
  volatile int packetReceived = 0;
  packetReceived = taille_du_message;
  // lecture du message recu
  LoRa.readBytes((byte *)&messageLora, packetReceived);
  header1_du_message = messageLora.header1;
  header2_du_message = messageLora.header2;
  version_du_message = messageLora.version;
  emetteur_du_message = messageLora.emetteur;
  numero_device = hexTodec(String(emetteur_du_message));
  destinataire_du_message = messageLora.destinataire;
  relais_du_message = messageLora.relais;
  numero_du_message = messageLora.numero_du_message;
  donnee1_du_message = messageLora.donnee1;
  donnee2_du_message = messageLora.donnee2;
  donnee3_du_message = messageLora.donnee3;
  donnee4_du_message = messageLora.donnee4;
  checksum_du_message = messageLora.checksum;
  *text_du_message = *messageLora.text;
#ifdef DEBUG
  // display des données reçues
  Serial.print(" header 1 = " + String(header1_du_message) + " header 2 = " + String(header2_du_message) + " version = " + String(version_du_message) + " De : " + String(emetteur_du_message) + " A : " + String(destinataire_du_message) + " Num de msg = " + String(numero_du_message));
  Serial.println(" donnee1 = " + String(donnee1_du_message) + " donnee2 = " + String(donnee2_du_message) + " donnee3 = " + String(donnee3_du_message) + " donnee4 = " + String(donnee4_du_message) + " cheksum = " + String(checksum_du_message) + " text = " + String(text_du_message));
#endif
  packetReceived = 0;  // clear for next time
void  sendMessage() {
  LoRa.beginPacket();                             // start packet
  LoRa.write((byte *)&messageLora, sizeof(messageLora));  // transmit packet
  LoRa.endPacket(true);  // finish packet and send it
#ifdef DEBUG
  Serial.print("Message envoyé : ");
  Serial.println("Sent  to: 0x" + String(messageLora.destinataire) + " - From: 0x" + String(messageLora.emetteur) + " - Relais: 0x" + String(messageLora.relais) + " - Message ID: " + String(messageLora.numero_du_message) + "Message:  " + *messageLora.text);
  //Serial.println("Msg envoyé " + String(msgCount) + " destination= " + String(destination));
  displayOLED(0, 1, 0, debut_ligne_sent + increment_ligne*0, 1, "Sent > " + String(messageLora.emetteur) + "/" + String(messageLora.destinataire),1);
  displayOLED(0, 1, 0, debut_ligne_sent + increment_ligne*1, 1, "Num:" + String(messageLora.numero_du_message) + " - Poid:" + String(donnee1_du_message), 1);
#endif
void displayOLED(int clearEcran, int ClearLigne, int positionHorizontale, int positionVerticale, int tailleText, String messageText, int couleur)
#ifdef DEBUG
  // Affichage OLED
  if (clearEcran == 1)
    display.clearDisplay();
    if (ClearLigne == 1)
      nettoyage_ligne_OLED(positionVerticale, couleur);
  display.setTextColor(couleur);
  display.setTextSize(tailleText);
  display.setCursor(positionHorizontale, positionVerticale);
  display.print(messageText);
  display.display();
#endif
void nettoyage_ligne_OLED(int ligne_a_nettoyer, int couleur_ligne)
  const int largeur_ecran = 127;
  const int hauteur_d_une_ligne = 7;
  int couleur_inverse =0;
  if (couleur_ligne == 1)
    couleur_inverse = 0;
   if (couleur_ligne == 0)
    couleur_inverse = 1;
  for (int h = ligne_a_nettoyer; h < ligne_a_nettoyer + hauteur_d_une_ligne; h++)
    for (int l = 0; l < largeur_ecran; l++)
      display.drawPixel(l, h, couleur_inverse);
unsigned int hexTodec(String hexString)
  // Procedure qui converti HEX en Dec - utilisé pour convertir l'adresse HEX des devices en increment ds le tableau des données
  unsigned int decValue = 0;
  int nextInt;
  for (int i = 0; i < hexString.length(); i++)
    nextInt = int(hexString.charAt(i));
    if (nextInt >= 48 && nextInt <= 57) nextInt = map(nextInt, 48, 57, 0, 9);
    if (nextInt >= 65 && nextInt <= 70) nextInt = map(nextInt, 65, 70, 10, 15);
    if (nextInt >= 97 && nextInt <= 102) nextInt = map(nextInt, 97, 102, 10, 15);
    nextInt = constrain(nextInt, 0, 15);
    decValue = (decValue * 16) + nextInt;
  return decValue;
long hexStringToDecimal(String hexString) {
  long decimalValue = 0;
  int hexLength = hexString.length();
  for (int i = 0; i < hexLength; i++) {
    char c = hexString.charAt(i);
    int digitValue;
    if (c >= '0' && c <= '9') {
      digitValue = c - '0';
    } else if (c >= 'A' && c <= 'F') {
      digitValue = 10 + (c - 'A');
    } else if (c >= 'a' && c <= 'f') {
      digitValue = 10 + (c - 'a');
      // Handle invalid characters if necessary
      continue;
    decimalValue = (decimalValue * 16) + digitValue;
  return decimalValue;
Rooting around a bit, I find a pinout for the Lora module here: Interfacing HPD13A - SX1276 IC Based LoRa Module with Arduino to Establish Communication with The Things Network
I've circled the NSS/SEL pin here:
You can solder a resistor onto it using a soldering iron with a small tip.
However, before doing this, see if you can find the schematic of the board you're using so it's clear what limitations there may be, and what other modifications may need to be done to optimize power use of this board.
The title of the post is (spelling corrected);
"Consumption of LoRa Module is 1.2mA in deep-sleep mode"
How do you know that is the case on your particular board, it might not be ?
What is the current consumption, in deep sleep, of that particular TTGO ESP32 board in deep sleep ?
Much easier to use seperate boards, you are in far more control of what the pins are doing and how they are connected. It just might not be possible to 'hack' a ready built board for real low deep sleep current.
Hello.
Thanks for your advise.
  1. About the consumption : I measure the following :
  • during the sleep mode, the board consumes 0,1mA/s (see the picture).
  • every 20mn, the board is waked up and send the data. I measured that during 10s the consumption is 162mA, and then 40mA during 7s.
    So, during 1h, it consumes 6 159mA, so average = 1,71mAh (1,71mA/s during 1h).
  1. Power I'm using = Lithium 18650 batterie : 3200mAh.
    I have calculated that it should stand around 2,6 months.
    But it doesn't.....
  2. Board : if I'm unable to solve the pb, it might order the ESP32 board and the Lora board seperately.
    What do you think about that models :
    ESP32 = Fire Beetle ESP32 or ESP-WROOM-32U ESP32 ?
    Lora module = Module LoRa 02 SX1278 433 MHz
Thanks and best regards.
CH
Your not going to get very far at all, in optimising deep sleep current, if you dont have a multimeter to measure the actual deep sleep current you are getting.
This is especially true when using ESP32 varients as they do odd things with the IO pins when going into deep sleep.
Here is the batterie I'm using.
Lithium 18650
Uou edited post #7 to retrospectivly add information that I commented in post #8 was completly missing. So my comment now looks daft and I only spotted you had made an update with the missing information by accident.
Hello.
  1. So : to be sure I understand well : is the diagram attached above what you recommand me to setup ?
    And :
  2. do you recommand me to connect also the VCC pin of the HX711 board (he green one) to the 3.3V ?
    Thanks.
    CH
Hi, I have made something similar. Spent 2 years to develop and understand.
Regarding green HX711 read this: Load cell amplifier HX711 - wrong ground? - #5 by Wawa
My tread regarding hive monitoring you can find ideas:
If you plan to use solar, and if temp is below 5 deg C then you may look into super capacitor's.
Also may be a good idea to buy a quality HX711 board from sparkfun
https://learn.sparkfun.com/tutorials/load-cell-amplifier-hx711-breakout-hookup-guide/all
this cards are the real deal. Also read about hooking up Vdd and Vcc to get the most out of HX711 chip.
M
Hello @Modesty : thanks a lot for your comments. But it fact, my project works fine and the way to connect the balance is not a problem : evrything is OK.
The only remaining point, and this is why I have opened a discusion, is about the energy consumption that I want (I need) to optimise.
@srnet gave me an advise to reduce the consumptin that is to connect the VSS of the Lora board to the 3.3V with a resistor.
I will do.
And my last question (to " srnet") is : "do I need to do the same for the VCC of the HX711 module ?"
I'm waiting for his confirmation (@Srnet) before doing the welding (the solder).
Cheers.
CH
The original post you quoted is worth a read, it was about preventing the ESP32 switching the LoRa module out of deep sleep by picking the problem up at the design stage of a board.
Whether the suggestions made are relavent to your built and complete product and would reduce deep sleep current, I dont have a clue, it uses different pins for a start, and I have never tested deep sleep on the board.
Put a scope on the LoRa device pins and see if they glitch when the ESP32 goes into deep sleep.
Hello Srnet. Sorry if my initial description was not so clear.
Recap : my objective is : to find a solution to reduce the energy consumption of the board as today, when I use a Lithium 18650 energy (3500 mAh), for the board, the board works for about 2 weeks, althought, when calculating the energy used by the board, it should work for more than 3 months.
I don't have a scope to analyse. But I have a simple ammeter. And it shows the following (I verified again this morning) :slight_smile:
  • during the sleep mode, the board consumes between 0,1mA and 0,2mA
  • So, during 1h (sleep - wakeup - Lora communication), it consumes 6 159mA, so average = 1,71mAh (1,71mA/s during 1h).
  • and so, with a battery that is 3200mAh, the board should work around 3 months.
And so, I still don't know why it doesn't stay "alive" for more than 2 weeks.
And so, I'm working on 2 directions :slight_smile:
  1. trying to understand why it only works during 2 weeks (when it should be 3 months)
  2. trying to reduce the consumption. And for that, I will try your solution with a PullUp resistor. To see if it decreases the consumtion.
You're juggling a bit with the units, but I agree that the run time with the measurement you provided should be around 10.7 weeks.
However, this does not take into account:
  • Effectively usable capacity of the battery; out of the specified 3200mAh, how much is really accessible/usable? The 3200mAh relies on a certain level of discharge and before this point is used, voltage may/will have dropped below a level where your circuit still works.
  • The specified capacity of the battery is given for a certain discharge rate. The capacity at the real discharge rate of your application may differ. It's conceivable/likely that the battery manufacturer bases their specification on the optimal discharge current.
  • The battery can suffer from self-discharge. This should be very low for Lithium batteries, but there's no guarantee it really is. Especially old or poorly manufactured cells may exhibit relatively high self discharge that is approximately in line with your 2-week lifespan.
  • A new Lithium battery may have to go through a couple of charge/discharge cycles before its optimal capacity is reached. Maybe your battery is simply too 'virgin' to last long (no pun intended....)
  • Note that temperature affects battery capacity; I understand your application operates in outside atmosphere, and low temperatures at night (or high altitude) and high temperatures during the daytime may erode battery capacity.
So there are all manner of factors that may explain why you're seeing a much shorter than anticipated battery lifetime, even if your measurements are correct. Note also that a relatively small measurement error can have a pretty large effect, and measurement errors are quite likely given the combination of a very small constant discharge rate that's alternated with possibly quite fierce/high peaks (beyond the 159mA you're actually reading).
hi. Thanks for your advise. My batteries are new. I have ordered new ones (and new models) to compare. I will see.
Clearly either the measurements or the battery capacity are not correct.
Buying a new battery is not really the answer, you really do need to measure the actual capacity of the battery before deciding somwthing is 'wrong'
Many multipurpose chargers will measure capacity, but you can just use a suitable power resistor and multimeter.
And if you want to be sure, how long in the real World application the battery lasts, just use a real small Lithium Polymer, they can be fouund with capacities around 50mAhr and are capable of reasonable currents, like in this test;
https://stuartsprojects.github.io/2020/02/20/just-how-long-can-a-sensor-battery-last.html
OK so for that LoRa application a tiny 155mAhr battery lasted 14 months, but the battery capacity had been specifically checked so you could easily work out low long a geniune 3200mAhr battery would last.
