I want to use WCS 1800 hall sensor to measure current flow using ADS1115 Analogue-Digital convert on my NodeMCU.
I have seen some examples using ACS712 but unable to find anything using WCS 1800 hall sensor.
Can anyone please help by providing a suitable direction?
You should power the sensor with 5volt, meaning you also must power the ADS1115 with 5volt.
Then you should also measure that 5volt supply with a second channel of the ADS1115,
because with the ADS1115, returned current value depends on current and supply voltage.
So you should compensate current readout with the change of sensor supply.
When the ADS1115 is powered with 5volt, then you also must use an I2C level converter between 5volt-logic ADS and 3.3volt-logic NodeMCU.
Leo..
