Current Source Sinewave PWM
I know that I can make an inverter using arduino by sine PWM of the voltage.
How about using the arduino to control a current source to make it sine PWM.
Edit: I need 10A or higher current output.
https://www.sciencedirect.com/topics/engineering/sinusoidal-pulse-width-modulation
The topic that you send is about voltage source sine PWM.
Add a voltage to current converter - like this
Can voltage to current converter handle PWM or sine wave already signal?
Can use I a transistor controlled by the PWM voltage to switch a current source to make it a current PWM then filter it?
@asd09 , do not cross-post. Thread locked.
