Megamorphf:
Thanks for the reply. Your code is neat and I like the mask idea .But I tried it and no luck. I
There are couple of issues.
There should have been a warning indicating a potential issue,
but the Arduino team silences all compiler warnings from the IDE by default.
If you turn on verbose output from the compiler using
[File]->[Preferences]
I would recommend always leaving this on to avoid missing important warnings.
When enabled, you will see a warning like this:
test1.pde: In function ‘void shiftOut_32b(uint8_t, uint8_t, uint32_t, uint8_t)’:
test1.pde:297:24: warning: left shift count >= width of type
The first issue is really insidious and often trips up people (including me).
The warning mentioned above will point to this line:
uint32_t mask = 1 << 31;
The default size in C is int. But on AVR int is 16 bits.
If you look closely, you can notice an issue. The 1 is an int by default which
on AVR is a 16 bit value but is being shifted by 31 bits.
This will not create the mask as intended it will create a mask of 0.
This should be changed to:
uint32_t mask = 1L << 31;
The next issue is silent and is from abusing the digitalWrite() API.
The API for digitalWrite() is:
digitalWrite(pin, value), where value is either HIGH or LOW.
The value parameter is not an arbitrary zero/nonzero value, it is HIGH or LOW.
The Arduino team should have used a stronger type for this rather than a simple define, that
way code like this would hard break rather than silently fail.
This particular case is quite interesting in that there are multiple issues cascading together.
The result of the mask expression
ID & mask
is 32 bits.
Normally what would be happening when using a 32 bit or even 16 bit "value" is that
since digitalWrite() is declared as a uint8_t (8 bits), digitalWrite() will only look at the lower 8 bits.
Code that abuses the API and attempts to pass down a zero/non zero values rather than HIGH or LOW
gets burned and will fail when the value is larger than 8 bits.
The safest way to ensure library code works, is not to abuse APIs.
This ensures reliability over time and portability.
So change the code to this:
digitalWrite(dataPin, (ID & mask) ? HIGH : LOW); // writes to data pin in MSB order
But even if the digitalWrite() API were not abused, it wouldn't matter in this particular case
because of another issue, which makes this case particularly interesting.
In this case because of the 31 bit shift issue earlier, the compiler realized that
mask is zero and hence since the result of masking anything with zero
is always zero, it always passes a zero down to digitalWrite().
The optimizer optimized out shifting of mask since it will always be zero
as well as the runtime mask with ID and simply calls digitalWrite(dataPin, 0);
(Optimizers are so smart....)
To make the code work, both issues need to be corrected:
void shiftOut_32b(uint8_t dataPin, uint8_t clockPin, uint32_t ID, uint8_t delay = 0)
for (uint8_t i=32; i>0; i--)
mask >>= 1;
digitalWrite(clockPin, HIGH);
if (delay>0) delayMicroseconds(delay); // adds a delay to the clock if needed
digitalWrite(clockPin, LOW);
In the larger picture, 32 bit values on the AVR are not efficient.
Here is the output generated by the above code:
00000648 <_Z12shiftOut_32bhhmh>:
648: 6f 92 push r6
64a: 7f 92 push r7
64c: 8f 92 push r8
64e: 9f 92 push r9
650: af 92 push r10
652: bf 92 push r11
654: cf 92 push r12
656: df 92 push r13
658: ef 92 push r14
65a: ff 92 push r15
65c: 0f 93 push r16
65e: 1f 93 push r17
660: 68 2e mov r6, r24
662: 76 2e mov r7, r22
664: 49 01 movw r8, r18
666: 5a 01 movw r10, r20
668: c0 2e mov r12, r16
66a: e1 2c mov r14, r1
66c: f1 2c mov r15, r1
66e: 01 2d mov r16, r1
670: 20 e8 ldi r18, 0x80 ; 128
672: 12 2f mov r17, r18
674: 90 e2 ldi r25, 0x20 ; 32
676: d9 2e mov r13, r25
678: 60 e0 ldi r22, 0x00 ; 0
67a: d8 01 movw r26, r16
67c: c7 01 movw r24, r14
67e: 88 21 and r24, r8
680: 99 21 and r25, r9
682: aa 21 and r26, r10
684: bb 21 and r27, r11
686: 00 97 sbiw r24, 0x00 ; 0
688: a1 05 cpc r26, r1
68a: b1 05 cpc r27, r1
68c: 09 f0 breq .+2 ; 0x690 <_Z12shiftOut_32bhhmh+0x48>
68e: 61 e0 ldi r22, 0x01 ; 1
690: 86 2d mov r24, r6
692: 0e 94 9a 06 call 0xd34 ; 0xd34 <digitalWrite>
696: 16 95 lsr r17
698: 07 95 ror r16
69a: f7 94 ror r15
69c: e7 94 ror r14
69e: 87 2d mov r24, r7
6a0: 61 e0 ldi r22, 0x01 ; 1
6a2: 0e 94 9a 06 call 0xd34 ; 0xd34 <digitalWrite>
6a6: cc 20 and r12, r12
6a8: 21 f0 breq .+8 ; 0x6b2 <_Z12shiftOut_32bhhmh+0x6a>
6aa: 8c 2d mov r24, r12
6ac: 90 e0 ldi r25, 0x00 ; 0
6ae: 0e 94 ad 05 call 0xb5a ; 0xb5a <delayMicroseconds>
6b2: 87 2d mov r24, r7
6b4: 60 e0 ldi r22, 0x00 ; 0
6b6: 0e 94 9a 06 call 0xd34 ; 0xd34 <digitalWrite>
6ba: da 94 dec r13
6bc: e9 f6 brne .-70 ; 0x678 <_Z12shiftOut_32bhhmh+0x30>
6be: 1f 91 pop r17
6c0: 0f 91 pop r16
6c2: ff 90 pop r15
6c4: ef 90 pop r14
6c6: df 90 pop r13
6c8: cf 90 pop r12
6ca: bf 90 pop r11
6cc: af 90 pop r10
6ce: 9f 90 pop r9
6d0: 8f 90 pop r8
6d2: 7f 90 pop r7
6d4: 6f 90 pop r6
6d6: 08 95 ret
It might be more efficient to call an 8 bit routine 4 times.
--- bill
