For Testing a low power battery application on a Uno form factor prototype board, I built this Uno clone kit but omitted the voltage regulator and power led : Helvetino Kit v1.01 - Mikrokontroller Arduino Boards Löt Kits - Boxtec Onlineshop. The description is in German but the picture gives enough of an idea. It is very sparse.
The entire project is here: Arduino IR Learning Remote Control
FYI
A very good friend to the community, Crossroads (miss him very much), made an Atmega1284 version of the UNO.
He had a jumper to enable disable the power option, no need for automatically selecting things.
Is he not on the forum anymore?
Do transistors use current?
I can't tell if this transistor uses current or just has a current rating.
He pasted
Your selection will easily pass 2A at logic level inputs.
I quite like the AO3401 for a P channel SOT23 MOSFET.
About $8.00 for 200 on eBay.
I quite like the IRLML2502 for a N channel SOT23 MOSFET.
About $7.00 for 100 on eBay.
That is what the Uno uses.
I'll use the AO3401 then. Thanks for the advice!
No, it is better as Rds(on) is less than 47milliohms at Vgs = 4.5V
Yours says 60 milliohms, however, 20milliohms difference isn’t much.
