I have made a custom arduino (same basic setup as the Boarduino). My problem is that I cannot upload sketches to it. I am using a bootloaded atmega328.
At first everything seems to go fine, but then I get a slew of errors and no upload.
The correct board and com port are selected in the tools menu. The serial cable I am using has been used to program countless other chips and even similar custom boards. The chip can be programed fine in my boarduino.
IDE output:
Binary sketch size: 3550 bytes (of a 30720 byte maximum)
C:\Program Files (x86)\arduino-0017\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\arduino-0017\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pm328p -cstk500v1 -P\\.\COM1 -b57600 -D -Uflash:w:C:\Users\Adam\Documents\Arduino\dollhouse1\applet\dollhouse1.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
System wide configuration file is "C:\Program Files (x86)\arduino-0017\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM1
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: Recv:
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [81] [20]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: A [41] . [82] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: Send: A [41] . [98] [20]
avrdude: Recv:
Hardware Version: 2
Firmware Version: 1.4368076
avrdude: Send: A [41] . [84] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x98
avrdude: Send: A [41] . [85] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x20
avrdude: Send: A [41] . [86] [20]
avrdude: Recv:
avrdude: Send: A [41] . [87] [20]
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x84
avrdude: Send: A [41] . [89] [20]
avrdude: Recv:
Vtarget : 197050696.5 V
Varef : 268691.6 V
Oscillator : 1.373 Hz
SCK period : 40.2 us
avrdude: Recv:
avrdude: Recv:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x85
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Recv:
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x20
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x41
avrdude done. Thank you.
Thanks for looking, -Adam
