Cut char with separator not working
Hello,
I'm currently trying to cut a char into several pieces of text.
  char data[] = "test,ca,va?,,test";
    char sep[] = ",";
  String *liste;
  liste = cutString(data,sep);
Serial.println(liste[0]);
String * cutString(char data[],char sep[]){
  int number = 0;
int size = String(data).length();
  for (int i = 0; i < size; i++){
    if(data[i]==sep[0]){
      number ++;
String * list;
char *d = strtok(data, ",");
list[0]=String(d);
int i =1;
while (d != NULL) {
       d = strtok(NULL, ",");
       list[i] = String(d);
       i++;
return list;
There is my code.
Everything works fine in the cutString function (when i do serial print, I retrieve what I want), but when called, I think there is something wrong, as nothing appears in serial monitor, and no build issue.
Can you help me please ?
Thanks you a lot !
I'm compiling for nodemcu 0.9 esp8266
String * list;
list[0]=String(d);
Oops.
Crazy mix of Strings and strings.
Why?
Why initialize the serial device more than once?I
Not really an installation issue, is it?
@mistano, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the Installation & Troubleshooting category.
I tried to do some things to debug my code, but I didn't removed these modifications. At the begining, I wanted to have a function taking a char input, a char separator, to return a list of all separated characters.
I agree with you that I did crazy things here, but I was very lost with all of that. Can you help me do it the good way please ?
Hello,
Thank you a lot for that, I will go to check that
consider
#define MAX_TOK   10
char **
cutString (
    const char *str,
    const char *sep )
    static char *tok [MAX_TOK];
    char  s[80];
    strcpy (s, str);
    tok [0] = strtok (s, sep);
    for (int n = 1; n < MAX_TOK && NULL != (tok [n] = strtok (NULL, sep)); n++)
    return tok;
void setup () {
    Serial.begin (9600);
    char **p = cutString ("test,ca,va?,,test", ",");
    while (*p)
        Serial.println (*p++);
void loop () {
