CYD ESP32 2.8" display issues
Hey I have a typical ESP32 cheap yellow display that is setup correctly, verified by compiler, active monitor shows prints and all expected functionality, yet the screen just lights up and shows a constant white light, nothing else, no color changes no text no nothing.
Please help by experience, I have asked 9 pro AI models, and none could solve this.
Show your wiring diagram and sketch (in <CODE> block) to verify it is set up correctly.
the config and pins are not edited, as the cheap yellow display 2.8 comes in presoldered. The sketch is:
#include <TFT_eSPI.h>
#include <SPI.h>
#include <WiFi.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
#include <time.h>
#include <esp_system.h>
#include <esp_timer.h>
#include <esp_adc_cal.h>
#include <XPT2046_Touchscreen.h>
// TFT_eSPI configuration for Cheap Yellow Display
#define TFT_MISO -1      // Not used
#define TFT_MOSI 23      // IO23
#define TFT_SCLK 18      // IO18
#define TFT_CS   5       // IO5
#define TFT_DC   2       // IO2
#define TFT_RST  4       // IO4
#define TFT_BL   15      // IO27 (Backlight control for CYD)
// Touch configuration
#define TOUCH_CS 21      // IO21 (XPT2046 touch controller)
// Display instance
TFT_eSPI tft = TFT_eSPI();
XPT2046_Touchscreen ts(TOUCH_CS);
// System information
struct SystemInfo {
  uint32_t freeHeap;
  uint32_t totalHeap;
  float cpuTemp;
  String currentTime;
  String currentDate;
  uint32_t sessionNumber;
  String wifiSSID;
  int32_t wifiRSSI;
  uint32_t wifiSpeed;
  uint32_t uptime;
} sysInfo;
// Boot sequence state
enum BootState {
  LOGO_DISPLAY,
  TITLE_DISPLAY,
  SYSTEM_INFO_DISPLAY,
  WIFI_CONNECTING,
  READY
BootState bootState = LOGO_DISPLAY;
unsigned long bootStartTime = 0;
const int BOOT_DELAY = 2000; // 2 seconds per screen
// WiFi network structure
struct WiFiNetwork {
  String ssid;
  int32_t rssi;
  uint8_t encryptionType;
// WiFi configuration
const char* defaultSSID = "Virtual Death Spot";
const char* defaultPassword = "Vita101Vita";
std::vector<WiFiNetwork> availableNetworks;
int selectedNetworkIndex = 0;
bool isSelectingNetwork = false;
// Display colors
#define BACKGROUND_COLOR TFT_BLACK
#define TEXT_COLOR TFT_WHITE
#define HIGHLIGHT_COLOR TFT_YELLOW
// Touch screen calibration
#define TOUCH_CALIBRATION_X 0
#define TOUCH_CALIBRATION_Y 0
#define TOUCH_CALIBRATION_X1 240  // Changed from 320 to match display width
#define TOUCH_CALIBRATION_Y1 320  // Changed from 240 to match display height
// System state
enum SystemState {
  BOOTING,
  WIFI_SELECTION,
  SYSTEM_INFO,
  CHAT_MODE
SystemState currentState = BOOTING;
// Chat interface variables
String inputBuffer = "";
String responseBuffer = "";
bool isWaitingForResponse = false;
int cursorY = 50;
const int MAX_LINES = 8;
const int LINE_HEIGHT = 25;
  Serial.println("Starting...");
  // Initialize display with more detailed sequence
  Serial.println("Initializing display...");
  // Hardware reset
  pinMode(TFT_RST, OUTPUT);
  digitalWrite(TFT_RST, HIGH);
  delay(100);
  digitalWrite(TFT_RST, LOW);
  delay(100);
  delay(100);
  tft.init();
  delay(100);
  // Software reset
  Serial.println("Resetting display...");
  tft.writecommand(ST7789_SWRESET);
  delay(150);
  // Exit sleep mode
  Serial.println("Exiting sleep mode...");
  tft.writecommand(ST7789_SLPOUT);
  delay(100);
  // Set color mode to 16-bit per pixel (0x05 = 16-bit color)
  tft.writecommand(ST7789_COLMOD);
  tft.writedata(0x06);  // Changed from 0x05 to 0x06 for 18-bit color
  delay(10);
  // Set display orientation (0x00 = normal, 0x60 = rotated)
  tft.writecommand(ST7789_MADCTL);
  tft.writedata(0x00);  // Changed back to 0x00 for normal orientation
  delay(10);
  // Set display parameters
  Serial.println("Setting display parameters...");
  // Frame rate control
  tft.writecommand(ST7789_FRMCTR1);
  tft.writedata(0x01);
  tft.writedata(0x2C);
  tft.writedata(0x2D);
  delay(10);
  tft.writecommand(ST7789_FRMCTR2);
  delay(10);
  // Display inversion control
  tft.writecommand(ST7789_INVCTR);
  tft.writedata(0x07);
  delay(10);
  // Power control
  tft.writecommand(ST7789_PWCTR1);
  tft.writedata(0xA2);
  tft.writedata(0x02);
  tft.writedata(0x84);
  delay(10);
  tft.writecommand(ST7789_PWCTR2);
  tft.writedata(0xC5);
  delay(10);
  tft.writecommand(ST7789_PWCTR3);
  tft.writedata(0x0A);
  delay(10);
  tft.writecommand(ST7789_PWCTR4);
  tft.writedata(0x8A);
  tft.writedata(0x2A);
  delay(10);
  tft.writecommand(ST7789_PWCTR5);
  tft.writedata(0xEE);
  delay(10);
  // VCOM voltage
  tft.writecommand(ST7789_VMCTR1);
  tft.writedata(0x0E);
  delay(10);
  // Turn on display
  Serial.println("Turning on display...");
  tft.writecommand(ST7789_DISPON);
  delay(100);
  // Set rotation
  Serial.println("Setting rotation...");
  tft.setRotation(0);
  // Clear screen
  Serial.println("Clearing screen...");
  tft.fillScreen(TFT_BLACK);
  delay(100);
  // Initialize backlight
  Serial.println("Initializing backlight...");
  pinMode(TFT_BL, OUTPUT);
  digitalWrite(TFT_BL, HIGH);
  // More visible test pattern with longer delays
  Serial.println("Starting display test pattern...");
  // Test 1: Full screen colors
  Serial.println("Drawing red screen...");
  tft.fillScreen(TFT_RED);
  delay(2000);
  Serial.println("Drawing green screen...");
  tft.fillScreen(TFT_GREEN);
  delay(2000);
  Serial.println("Drawing blue screen...");
  tft.fillScreen(TFT_BLUE);
  delay(2000);
  // Test 2: Grid pattern
  Serial.println("Drawing grid pattern...");
  tft.setTextColor(TFT_WHITE);
  tft.setTextSize(2);
  tft.setCursor(10, 10);
  tft.println("Display Test");
  // Draw a grid
  for(int x = 0; x < tft.width(); x += 20) {
    tft.drawLine(x, 0, x, tft.height(), TFT_WHITE);
  for(int y = 0; y < tft.height(); y += 20) {
    tft.drawLine(0, y, tft.width(), y, TFT_WHITE);
  delay(2000);
  // Test 3: Text test
  Serial.println("Drawing text test...");
  tft.setTextColor(TFT_YELLOW);
  tft.setTextSize(3);
  tft.setCursor(40, 80);
  tft.println("ARPA CORP");
  tft.setTextSize(2);
  tft.setCursor(40, 120);
  delay(2000);
  // Initialize system info
  initSystemInfo();
  Serial.println("System info initialized");
  // Start boot sequence
  bootStartTime = millis();
  bootState = LOGO_DISPLAY;  // Explicitly set initial state
  showBootSequence();
  Serial.println("Boot sequence started");
  // Initialize WiFi and scan networks
  initWiFi();
  // Initialize touch
  touch_init();
  // Enter chat mode
  currentState = CHAT_MODE;
  initChatInterface();
  Serial.println("Setup complete");
void initSystemInfo() {
  // Initialize NTP for time
  configTime(0, 0, "pool.ntp.org", "time.nist.gov");
  // Generate session number (based on boot time)
  sysInfo.sessionNumber = esp_timer_get_time() / 1000000;
  // Initialize ADC for temperature
  esp_adc_cal_characteristics_t adc_chars;
  esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_11, ADC_WIDTH_BIT_12, 1100, &adc_chars);
void updateSystemInfo() {
  // Update memory info
  sysInfo.freeHeap = ESP.getFreeHeap();
  sysInfo.totalHeap = ESP.getHeapSize();
  // Update temperature
  sysInfo.cpuTemp = (analogRead(36) * 3.3 / 4095.0) * 100.0; // Convert to Celsius
  // Update time
  struct tm timeinfo;
  if (getLocalTime(&timeinfo)) {
    char timeStr[9];
    char dateStr[11];
    strftime(timeStr, sizeof(timeStr), "%H:%M:%S", &timeinfo);
    strftime(dateStr, sizeof(dateStr), "%Y-%m-%d", &timeinfo);
    sysInfo.currentTime = String(timeStr);
    sysInfo.currentDate = String(dateStr);
  // Update WiFi info
  if (WiFi.status() == WL_CONNECTED) {
    sysInfo.wifiSSID = WiFi.SSID();
    sysInfo.wifiRSSI = WiFi.RSSI();
    sysInfo.wifiSpeed = WiFi.channel();
  // Update uptime
  sysInfo.uptime = (millis() - bootStartTime) / 1000;
void showBootSequence() {
  switch (bootState) {
    case LOGO_DISPLAY:
      showLogo();
      if (millis() - bootStartTime > BOOT_DELAY) {
        bootState = TITLE_DISPLAY;
    case TITLE_DISPLAY:
      showTitle();
        bootState = SYSTEM_INFO_DISPLAY;
    case SYSTEM_INFO_DISPLAY:
      updateSystemInfo();
      showSystemInfo();
        bootState = WIFI_CONNECTING;
    case WIFI_CONNECTING:
      // WiFi connection is handled in initWiFi()
    case READY:
      // Ready for chat mode
void showLogo() {
  Serial.println("Showing logo...");
  tft.setTextSize(3);
  // Draw ARPA CORP logo
  // Draw a simple logo design
  tft.drawRect(30, 30, 260, 40, TFT_YELLOW);
  tft.drawLine(30, 50, 290, 50, TFT_YELLOW);
  Serial.println("Logo displayed");
void showTitle() {
  tft.fillScreen(BACKGROUND_COLOR);
  tft.setTextColor(TEXT_COLOR);
  tft.setTextSize(2);
  // Display title
  tft.setCursor(10, 80);
  tft.println("Prototype Portable");
  tft.setCursor(10, 110);
  tft.println("SCI Interface Kit");
  // Draw a border
  tft.drawRect(5, 70, 310, 60, HIGHLIGHT_COLOR);
void showSystemInfo() {
  tft.setTextSize(1);
  int y = 10;
  int lineHeight = 15;
  // System Information
  tft.setTextColor(HIGHLIGHT_COLOR);
  tft.setCursor(10, y);
  tft.println("System Information");
  y += lineHeight * 2;
  // Memory
  tft.printf("Memory: %d/%d KB", sysInfo.freeHeap/1024, sysInfo.totalHeap/1024);
  y += lineHeight;
  // Temperature
  tft.printf("CPU Temp: %.1f°C", sysInfo.cpuTemp);
  y += lineHeight;
  // Time and Date
  tft.printf("Time: %s", sysInfo.currentTime.c_str());
  y += lineHeight;
  tft.printf("Date: %s", sysInfo.currentDate.c_str());
  y += lineHeight;
  // Session
  tft.printf("Session: #%d", sysInfo.sessionNumber);
  y += lineHeight;
  // WiFi Information
    tft.printf("WiFi: %s", sysInfo.wifiSSID.c_str());
    y += lineHeight;
    tft.printf("Signal: %d dBm", sysInfo.wifiRSSI);
    y += lineHeight;
    tft.printf("Channel: %d", sysInfo.wifiSpeed);
  y += lineHeight;
  // Uptime
  tft.printf("Uptime: %d seconds", sysInfo.uptime);
  if (bootState != READY) {
    showBootSequence();
    return;
  switch(currentState) {
    case BOOTING:
      // Handle booting state
    case WIFI_SELECTION:
      if (isSelectingNetwork) {
        handleNetworkSelection();
    case SYSTEM_INFO:
      // Handle system info state
    case CHAT_MODE:
      handleChatMode();
void touch_init() {
  ts.begin();
  ts.setRotation(0);
  Serial.println("Touch screen initialized");
void initWiFi() {
  currentState = WIFI_SELECTION;
  tft.setTextSize(2);
  tft.println("Scanning WiFi networks...");
  // Start WiFi in station mode
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  // Scan for networks
  int numNetworks = WiFi.scanNetworks();
  availableNetworks.clear();
  for (int i = 0; i < numNetworks; i++) {
    WiFiNetwork network;
    network.ssid = WiFi.SSID(i);
    network.rssi = WiFi.RSSI(i);
    network.encryptionType = WiFi.encryptionType(i);
    availableNetworks.push_back(network);
  // Sort networks by signal strength
  std::sort(availableNetworks.begin(), availableNetworks.end(),
    [](const WiFiNetwork& a, const WiFiNetwork& b) {
      return a.rssi > b.rssi;
  if (availableNetworks.size() > 0) {
    isSelectingNetwork = true;
    displayNetworkSelection();
    // Fallback to default network
    connectToDefaultNetwork();
void displayNetworkSelection() {
  tft.setTextSize(2);
  tft.println("Select WiFi Network:");
  for (int i = 0; i < availableNetworks.size() && i < 5; i++) {
    tft.setCursor(20, 40 + (i * 30));
    if (i == selectedNetworkIndex) {
      tft.print("> ");
    String networkInfo = availableNetworks[i].ssid;
    networkInfo += " (";
    networkInfo += availableNetworks[i].rssi;
    networkInfo += " dBm)";
    tft.println(networkInfo);
  tft.setCursor(10, 200);
  tft.println("Up/Down: Select");
  tft.setCursor(10, 230);
  tft.println("Enter: Connect");
void handleNetworkSelection() {
  // Only touch input supported for now
  // You can add touch-based up/down/enter logic here if desired
void connectToSelectedNetwork() {
  if (selectedNetworkIndex < availableNetworks.size()) {
    tft.println("Connecting to:");
    tft.setCursor(10, 40);
    tft.println(availableNetworks[selectedNetworkIndex].ssid);
    // Try to connect to the selected network
    WiFi.begin(availableNetworks[selectedNetworkIndex].ssid.c_str());
    int attempts = 0;
    while (WiFi.status() != WL_CONNECTED && attempts < 20) {
      tft.print(".");
      attempts++;
      tft.println("\nConnected!");
      currentState = SYSTEM_INFO;
      tft.println("\nConnection failed!");
      tft.println("Falling back to default network...");
      delay(2000);
void connectToDefaultNetwork() {
  tft.println("Connecting to default network...");
  WiFi.begin(defaultSSID, defaultPassword);
  int attempts = 0;
    tft.print(".");
    attempts++;
    tft.println("Please check your WiFi settings.");
    delay(2000);
    // Retry connection
    initWiFi();
void initChatInterface() {
  tft.setTextSize(2);
  tft.println("Chat Mode Ready");
void handleChatMode() {
  // Use XPT2046 touch input
  if (ts.touched()) {
    TS_Point p = ts.getPoint();
    // Convert touch coordinates to screen coordinates
    uint16_t x = map(p.x, 0, 4095, 0, tft.width());
    uint16_t y = map(p.y, 0, 4095, 0, tft.height());
    if (y > 200) {
      handleTouchInput(x, y);
  // Display current chat
  displayChat();
void handleTouchInput(uint16_t x, uint16_t y) {
  if (isWaitingForResponse) return;
  // Simple keyboard layout
  if (y > 200 && y < 240) {
    if (x < 80) inputBuffer += "A";
    else if (x < 160) inputBuffer += "B";
    else if (x < 240) inputBuffer += "C";
    else inputBuffer += "D";
    if (inputBuffer.length() > 20) {
      sendToGemini();
void displayChat() {
  // Display chat history
  tft.setTextSize(2);
  if (inputBuffer.length() > 0) {
    tft.setCursor(10, cursorY);
    tft.print("YOU: ");
    tft.println(inputBuffer);
    cursorY += LINE_HEIGHT;
  if (responseBuffer.length() > 0) {
    tft.print("OPSIE_32: ");
    tft.println(responseBuffer);
  // Display input area
  tft.drawRect(0, 200, 320, 40, HIGHLIGHT_COLOR);
  tft.setCursor(10, 210);
  tft.print("Input: ");
  tft.print(inputBuffer);
void sendToGemini() {
    HTTPClient http;
    String url = String(GEMINI_API_URL) + "?key=" + GEMINI_API_KEY;
    http.begin(url);
    http.addHeader("Content-Type", "application/json");
    // Build JSON payload with system prompt and user message
    String jsonPayload = "{";
    jsonPayload += "\"contents\":[";
    jsonPayload += "{\"role\":\"user\",\"parts\":[{\"text\":\"" + String(SYSTEM_PROMPT) + "\"}]},";
    jsonPayload += "{\"role\":\"user\",\"parts\":[{\"text\":\"" + inputBuffer + "\"}]}";
    jsonPayload += "]}";
    int httpResponseCode = http.POST(jsonPayload);
    if (httpResponseCode > 0) {
      String response = http.getString();
      parseGeminiResponse(response);
    http.end();
  inputBuffer = "";
void parseGeminiResponse(String response) {
  DynamicJsonDocument doc(1024);
  deserializeJson(doc, response);
  // Extract the response text
  responseBuffer = doc["candidates"][0]["content"]["parts"][0]["text"].as<String>();
  // Ensure response is short (1-2 sentences)
  int firstPeriod = responseBuffer.indexOf('.');
  if (firstPeriod != -1) {
    int secondPeriod = responseBuffer.indexOf('.', firstPeriod + 1);
    if (secondPeriod != -1) {
      responseBuffer = responseBuffer.substring(0, secondPeriod + 1);
Show the power supply... which would have been in the wiring diagram.
Awesome! You do not show a power supply.
Message received. Leaving now.
Im sorry I'm a begginner what do you mean by power supply? I plug it into my computer via micro USB.
Στις Πέμ 8 Μαΐ 2025, 10:01 μ.μ. ο χρήστης xfpd via Arduino Forum <notifications@arduino.discoursemail.com> έγραψε:
It's this one:
https://github.com/witnessmenow/ESP32-Cheap-Yellow-Display
Στις Πέμ 8 Μαΐ 2025, 11:28 μ.μ. ο χρήστης Vladimiros Peilivanidis <vpeilivanidis@gmail.com> έγραψε:
Yes, that is a power supply.
Where do you find your display here?
There seems to be a setup, too.
I fall into first (left green).
Also have installed all libraries and dependencies. Can show my user settings h file if it helps.
Στις Παρ 9 Μαΐ 2025, 12:08 π.μ. ο χρήστης xfpd via Arduino Forum <notifications@arduino.discoursemail.com> έγραψε:
Yes, the more information, the better.
are you sure you have the correct GPIO pins selected
the circuit of post 5 shows
can you give a link to the CYD?
ESP32 Arduino LVGL WiFi & Wireless Development Board with 7.11cm Smart LCD TFT Display, Touch Screen, and USB Power - Brightness Controls, Delay Box, Test Mode, Freertos Operating System
https://www.temu.com/goods.html?_bg_fs=1&goods_id=601099812806171&sku_id=17593414150581
looking 2.8inch_ESP32-2432S028R\1-Demo\Demo_Arduino\3_4-1_TFT_Rainbow the User_Setup.h defines
#define TFT_MOSI 13 // In some display driver board, it might be written as "SDA" and so on.
#define TFT_SCLK 14
#define TFT_CS   15  // Chip select control pin
#define TFT_DC   2  // Data Command control pin
#define TFT_RST  12  // Reset pin (could connect to Arduino RESET pin)
#define TFT_BL   21  // LED back-light
#define TOUCH_CS 33     // Chip select pin (T_CS) of touch screen
which matches the definitions I use with my CYD
Thank you Horace. Will try in a bit.
