Hey all I was wondering if this would be the correct way of daisy chaining 3 CD74HC4067 together?
I'm pretty sure that's how I've done it before with HC4051's so you should be OK.
Always add de-coupling capacitors on all your power pins.
Make sure data input is between 3v3 to 0v
I think it will give 1 analog signal out of 48. What part are you using the Schematic shows a different part?
Which part is different?
The part number CD40675M / CD74HC4067 Different families same pinout and function.
Yeah just now noticed that. They should all be labeled CD40675M.
If I never made that mistook I would have never caught it:-)
I've been finding some schematics of Mux in daisy chaining and it looks like EN goes to GRN while the "Z" (COM) goes to a different GPIO pin:
So now im not sure how this should be hooked up....
- The Z pins go to Analog inputs on the Arduino.
The Y0-15 pins go to 0 to 3V3 inputs.
