Daisy Chaining Shift Registers Code Question
Hi, I am trying to set up two 74HC595 shift registers daisy chained to one another in order to output 16 bits of information at once through only a few pins on the Arduino. I found this lovely tutorial on how to control one shift register, but I am unable to figure out what I should modify to allow myself to output 16 bits of information instead of just 8 bits. This is the code they used in the example. I have lots of programming experience in Java but I'm newer to C, so I'm just caught on what I should change. Thanks in advance, I will also link the tutorial I followed to get the first one working.
int latchPin = 5;  // Latch pin of 74HC595 is connected to Digital pin 5
int clockPin = 6; // Clock pin of 74HC595 is connected to Digital pin 6
int dataPin = 4;  // Data pin of 74HC595 is connected to Digital pin 4
byte leds = 0;    // Variable to hold the pattern of which LEDs are currently turned on or off
 * setup() - this function runs once when you turn your Arduino on
 * We initialize the serial connection with the computer
  // Set all the pins of 74HC595 as OUTPUT
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
 * loop() - this function runs over and over again
  leds = 0; // Initially turns all the LEDs off, by giving the variable 'leds' the value 0
  updateShiftRegister();
  for (int i = 0; i < 8; i++) // Turn all the LEDs ON one by one.
    bitSet(leds, 9);    // Set the bit that controls that LED in the variable 'leds'
 * updateShiftRegister() - This function sets the latchPin to low, then calls the Arduino function 'shiftOut' to shift out contents of variable 'leds' in the shift register before putting the 'latchPin' high again.
void updateShiftRegister()
   digitalWrite(latchPin, LOW);
   shiftOut(dataPin, clockPin, LSBFIRST, leds);
   digitalWrite(latchPin, HIGH);
https://lastminuteengineers.com/74hc595-shift-register-arduino-tutorial/#:~:text=A%20shift%20register%20allows%20you,using%20only%20three%20input%20pins.
Welcome,
Look here :slight_smile: Controlling 16 LED's with two 74HC595 Shift register
Hint: "byte leds = 0; // Variable to hold the pattern of which LEDs are currently turned on or off" A byte is 8 bits, an int is 16 bits.
uint16_t leds = 0;
   shiftOut(dataPin, clockPin, LSBFIRST, lowByte(leds));
   shiftOut(dataPin, clockPin, LSBFIRST, highByte(leds));
