For my final projects (balancing robot), I acquired 2X 350 RPM Pololu motors with integrated encoders
and a 14A dual motor driver
In an attempt to understand DC motor control, I developped two source codes
The first one is real basic, giving motion control:
- forward(power)
- backward(power)
- stop()
power parameter beeing the PWM value (0-255) sent to the motor
// MD03A_Motor_basic
// Test MD03a / Pololu motor
#define InA1 10 // INA motor pin
#define InB1 11 // INB motor pin
#define PWM1 6 // PWM motor pin
pinMode(InA1, OUTPUT);
pinMode(InB1, OUTPUT);
pinMode(PWM1, OUTPUT);
motorForward(200); //(25%=64; 50%=127; 100%=255)
delay(5000);
motorStop();
delay(2000);
motorBackward(200);
delay(5000);
void motorForward(int PWM_val) {
analogWrite(PWM1, PWM_val);
digitalWrite(InA1, LOW);
digitalWrite(InB1, HIGH);
void motorBackward(int PWM_val) {
digitalWrite(InA1, HIGH);
digitalWrite(InB1, LOW);
void motorStop() {
analogWrite(PWM1, 0);
The "full blown" gives PID control over speed parameter, pretty much as the "Cruse Control" feature found on modern cars.
When mechanicaly loaded, the system will increase PWM in an attempt to maintain "actual speed" at "target speed" level.
This is the only way to run at low speed (20 RPM) while maintaining a high torque
"Actual speed" is computed based upon the encoder informations, acquired in an interrupt routine.
Voltage ("low bat" warning) and current (overheating) are also continuously monitored
Speed and direction of rotation are adjustable through computer keyboard
// Test MD03a / Pololu motor with encoder
// speed control (PI), V & I display
// Credits:
// Dallaby http://letsmakerobots.com/node/19558#comment-49685
// Bill Porter http://www.billporter.info/?p=286
// bobbyorr (nice connection diagram) http://forum.pololu.com/viewtopic.php?f=15&t=1923
#define encodPinA1 3 // encoder A pin
#define encodPinB1 8 // encoder B pin
#define Vpin 0 // battery monitoring analog pin
#define Apin 1 // motor current monitoring analog pin
#define CURRENT_LIMIT 1000 // high current warning
#define LOW_BAT 10000 // low bat warning
#define LOOPTIME 100 // PID loop time
#define NUMREADINGS 10 // samples for Amp average
int readings[NUMREADINGS];
unsigned long lastMilli = 0; // loop timing
unsigned long lastMilliPrint = 0; // loop timing
int speed_req = 300; // speed (Set Point)
int speed_act = 0; // speed (actual value)
int PWM_val = 0; // (25% = 64; 50% = 127; 75% = 191; 100% = 255)
int voltage = 0; // in mV
int current = 0; // in mA
volatile long count = 0; // rev counter
float Kp = .4; // PID proportional control Gain
float Kd = 1; // PID Derivitave control gain
analogReference(EXTERNAL); // Current external ref is 3.3V
Serial.begin(115600);
pinMode(encodPinA1, INPUT);
pinMode(encodPinB1, INPUT);
digitalWrite(encodPinA1, HIGH); // turn on pullup resistor
digitalWrite(encodPinB1, HIGH);
attachInterrupt(1, rencoder, FALLING);
for(int i=0; i<NUMREADINGS; i++) readings[i] = 0; // initialize readings to 0
getParam(); // check keyboard
if((millis()-lastMilli) >= LOOPTIME) { // enter tmed loop
lastMilli = millis();
getMotorData(); // calculate speed, volts and Amps
PWM_val= updatePid(PWM_val, speed_req, speed_act); // compute PWM value
analogWrite(PWM1, PWM_val); // send PWM to motor
printMotorInfo(); // display data
void getMotorData() { // calculate speed, volts and Amps
static long countAnt = 0; // last count
speed_act = ((count - countAnt)*(60*(1000/LOOPTIME)))/(16*29); // 16 pulses X 29 gear ratio = 464 counts per output shaft rev
countAnt = count;
voltage = int(analogRead(Vpin) * 3.22 * 12.2/2.2); // battery voltage: mV=ADC*3300/1024, voltage divider 10K+2K
current = int(analogRead(Apin) * 3.22 * .77 *(1000.0/132.0)); // motor current - output: 130mV per Amp
current = digital_smooth(current, readings); // remove signal noise
int updatePid(int command, int targetValue, int currentValue) { // compute PWM value
float pidTerm = 0; // PID correction
int error=0;
static int last_error=0;
error = abs(targetValue) - abs(currentValue);
pidTerm = (Kp * error) + (Kd * (error - last_error));
last_error = error;
return constrain(command + int(pidTerm), 0, 255);
void printMotorInfo() { // display data
if((millis()-lastMilliPrint) >= 500) {
lastMilliPrint = millis();
Serial.print("SP:"); Serial.print(speed_req);
Serial.print(" RPM:"); Serial.print(speed_act);
Serial.print(" PWM:"); Serial.print(PWM_val);
Serial.print(" V:"); Serial.print(float(voltage)/1000,1);
Serial.print(" mA:"); Serial.println(current);
if (current > CURRENT_LIMIT) Serial.println("*** CURRENT_LIMIT ***");
if (voltage > 1000 && voltage < LOW_BAT) Serial.println("*** LOW_BAT ***");
void rencoder() { // pulse and direction, direct port reading to save cycles
if (PINB & 0b00000001) count++; // if(digitalRead(encodPinB1)==HIGH) count ++;
else count--; // if (digitalRead(encodPinB1)==LOW) count --;
int getParam() {
char param, cmd;
if(!Serial.available()) return 0;
delay(10);
param = Serial.read(); // get parameter byte
cmd = Serial.read(); // get command byte
Serial.flush();
switch (param) {
case 'v': // adjust speed
if(cmd=='+') {
speed_req += 20;
if(speed_req>400) speed_req=400;
if(cmd=='-') {
speed_req -= 20;
if(speed_req<0) speed_req=0;
case 's': // adjust direction
if(cmd=='+'){
if(cmd=='-') {
case 'o': // user should type "oo"
speed_req = 0;
default:
Serial.println("???");
int digital_smooth(int value, int *data_array) { // remove signal noise
static int ndx=0;
static int count=0;
static int total=0;
total -= data_array[ndx];
data_array[ndx] = value;
total += data_array[ndx];
ndx = (ndx+1) % NUMREADINGS;
if(count < NUMREADINGS) count++;
return total/count;
Credits: (Inspiration rarely comes from the Vacuum) ![]()
Bill Porter SAGAR Update, New Motor Controller and Motors « The Mind of Bill Porter
Anyone feeling like buildind a library ??
Enjoy
