DC motors POWER advice
Hello everyone!!!
I have an arduino nano and a robot with 2 wheels,I use the l293d driver and I also use "DC Motor in Micro Servo Body" (find it in Google).
My connection is here :
The voltage range for my motors I use (find it in Google as "DC Motor in Micro Servo Body") is 4-6 Volt,current = 650mA , speed = 130 RPM
So, I use a 9 Volt battery for my 2 motors.
My question is if there is any problem for the motors (or arduino).
I hope you help me...
Thank you!!
Connection:
https://www.google.com/search?biw=1920&bih=937&tbm=isch&sa=1&ei=w9ZiXajpBbWd1fAPg6yxqAY&q=l293d+arduino+2+motores&oq=arduino+2+l293d&gs_l=img.1.0.0i8i30.4971.4971..6250...0.0..0.185.185.0j1......0....1..gws-wiz-img.9hmgpK8eznw#imgrc=oS3ZTZmjfIecRM:
Small 9V batteries won't power motors satifactorily, they are low current. Assume your motor pulls more than 1A at stall, and that PP3-sized 9V alkaline batteries struggle with more than 0.05A... 4 AA's might be a better choice, or a small 2S LiPo pack (7.4V nominal).
NiMH 9V rechargables might fare better than alkaline, BTW. If you stick to batteries for which there is a datasheet available (good brands, basically), you are having to guess these things.
With this 9 Volt battery I use (you can find it here:https://www.google.com/search?q=9+volt+battery+Okcell&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjmsJag2Z7kAhVKsaQKHWMYAgMQ_AUIESgB&biw=1920&bih=937#imgrc=zANrKAswxoVrnM:)
my robot goes fast(very very well),but I 'm worried for the voltage(if this can damage the motors)
Thank you...
With this 9 Volt battery I use,is there a propability to damage the motors?
Then don't drive it to 100%. Use lower PWM setting.
ok.
Thanks
