bonjour,
utilisant un programme de domotique j'aimerai envoyer les code rfid de mes cartes via ethernet
je possede une carte rc522 connecte à un arduino mega + w5100.
j'ai utilisé le code suivant pour recuperer le code UID d'une carte
* Dump block 0 of a MIFARE RFID card using a RFID-RC522 reader
* Uses MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
* Pin layout should be as follows:
* Signal Pin Pin Pin
* Arduino Uno Arduino Mega MFRC522 board
* Reset 9 5 RST
* SPI SS 10 53 SDA
* SPI MOSI 11 52 MOSI
* SPI MISO 12 51 MISO
* SPI SCK 13 50 SCK
* Hardware required:
* Arduino
* PCD (Proximity Coupling Device): NXP MFRC522 Contactless Reader IC
* PICC (Proximity Integrated Circuit Card): A card or tag using the ISO 14443A interface, eg Mifare or NTAG203.
* The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 53 //Arduino Uno; CHANGED TO 8 TO AVOID CONFLICT WITH ETHERNET
#define RST_PIN 5
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println("Print block 0 of a MIFARE PICC ");
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) return;
Serial.print("Card UID:"); //Dump UID
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
Serial.print(" PICC type: "); // Dump PICC type
byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
Serial.println(mfrc522.PICC_GetTypeName(piccType));
byte buffer[18];
byte block = 0;
byte status;
//Serial.println("Authenticating using key A...");
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print("PCD_Authenticate() failed: ");
Serial.println(mfrc522.GetStatusCodeName(status));
return;
// Read block
byte byteCount = sizeof(buffer);
status = mfrc522.MIFARE_Read(block, buffer, &byteCount);
Serial.print("MIFARE_Read() failed: ");
else // Dump data
for (byte index = 0; index < 16; index++) {
Serial.print(buffer[index] < 0x10 ? " 0" : " ");
Serial.print(buffer[index], HEX);
if ((index % 4) == 3) Serial.print(" ");
Serial.println(" ");
mfrc522.PICC_HaltA(); // Halt PICC
mfrc522.PCD_StopCrypto1(); // Stop encryption on PCD
je suppose que ce sont les lignes qui suivent : Serial.print("Card UID:");
qui extraient l'UID de chaque carte
mais comment déclarer la suite pour pouvoir l'envoyer via ethernet avec un code sendget
merci
mickael
