Decoding serial data
I`m trying to send commands in the following format Axxxx where A is my command letter, eg A, B, C, D.... and xxxx is a float data value, e.g 1.02, 10.05, 12.6.
I can read the serial using the following;
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      stringComplete = true;
and i can get the letter but i`m struggling to also return the float data value. Can someone please give me some pointers.
Many thanks
James
Sure thing.
Don't use Strings.
Post ALL of your code.
char *pThisIsAPointer;
If you insist on pissing away resources using Strings, when you have the last character in the packet (How will you know that?), extract the String contents as a string (NULL terminated array of chars, which is what you SHOULD be using), determine the letter that starts the string (the command), then replace the first letter with a space, and call atof() with the string as input.
Could you use ParseFloat?
So this was the code i was trying to get working, not brilliant but i`m just learning at the moment.
If i get a command R then i need to read some analogue channels. If i get a V value then i need to figure out the data value and then send this value to a digital Pot. There will be more commands based on other letters that do other things.
    if (stringComplete) {
      int val = inputString.charAt(0);
      int len = inputString.length();
      switch (val){
        case 82: //R
          Read(); //Reads some analogue channels
        case 86: //V
         float voltageVal =(inputString.substring(1,len-1)).parseFloat;
          digitalPotWrite(voltageVal); //write a voltage to a digital POT.
        default:{}
      inputString = "";
      stringComplete=false;
Hint: save yourself a comment
switch (val){
        case 'R':
Thanks for the tip. With the tip and a little bit of web surfing i managed to figure it out. Probably not the most elegant way of doing it but it at least works.
      switch (val){
        case 'R':
         //Serial.println(inputString.substring(1,len-1));
          Read();
        case 'V':
          String DataVal = inputString.substring(1,len-1);
          char carray[DataVal.length() + 1]; //Array size
          DataVal.toCharArray(carray, sizeof(carray)); //put DataVal into an array
          float VoltageVal = atof(carray) ;   //Change to float value
          digitalPotWrite(VoltageVal);
        default:{}
      inputString = "";
