Hello Everyone,
Any practical suggestions for detecting microphone use before an amp? I have a lot of microphones that I would like to be able to detect which individual one is being used, before they go into a marshaling board, as after that point, i cannot tell at the level of detail that I need.
And yes, these mics are already in place, and adding an extra wire to the switch on the mic is not a practical option, although it would be nice. So it has to be monitoring for a signal. I have around 60 inputs to monitor.
Thanks in advance for any suggestions!
Has anyone got any ideas?
You might get a better responce if it was clearer what you wanted to acheave.
What do you mean by microphone use? Please give an example.
Right you are - sorry about that!
These are hand-held mics (similar to a cb microphone used on mounted units on trucks etc except without a speaker), and they have a switch on them that is depressed to activate the mic. There is no way of running another wire to the switch on the mic, which would be the ideal way to do it. I was hoping I would be able to detect somehow the AC signal that the voice generates. I want to light an LED when the mic is in use. If it flickers on an off between words etc, that is fine (well a delay would fix that, actually
Hopefully, that is enough information? Let me know if its not.
Thanks!
i had this code to an other projrct of mine,
adjust the thresshold value to your mic.
it will work for all analog ins in any arduino .
microphone sketch
SparkFun breakout board for Electret Microphone is connected to analog pin 0
int currentState = 0; //the default state
int wait = 100; //no need to wait, nothing has happened yet
int flag =0;
const int ledPin = 13; //the code will flash the LED in pin 13
const int middleValue = 512; //the middle of the range of analog values
const int numberOfSamples = 16; //how many readings will be taken each time
int sample; //the value read from microphone each time
long signal; //the reading once you have removed DC offset
long averageReading; //the average of that loop of readings
long runningAverage=0; //the running average of calculated values
const int averagedOver= 4; //how quickly new values affect running average
//bigger numbers mean slower
const int threshold=32000; //at what level the light turns on
pinMode(ledPin, OUTPUT);
long sumOfSquares = 0;
for (int i=0; i<numberOfSamples; i++) { //take many readings and average them
sample = analogRead(0); //take a reading
signal = (sample - middleValue); //work out its offset from the center
signal *= signal; //square it to make all values positive
sumOfSquares += signal; //add to the total
averageReading = sumOfSquares/numberOfSamples; //calculate running average
runningAverage=(((averagedOver-1)*runningAverage)+averageReading)/averagedOver;
if (runningAverage>threshold){ //is average more than the threshold ?
digitalWrite(ledPin, HIGH); //if it is turn on the LED
else{
digitalWrite(ledPin, LOW); //if it isn't turn the LED off
A switch in the microphone will disconnect something. However, that something depends on what type of microphone you have.
It should be possible to detect the effect of that switch on the impedance of the line and not have to rely on and signal from speaking. I would do some measurements with a voltmeter and oscilloscope to determine what effects you can see with you your specific microphone.
Detecting a minimum signal to activate something on a sound system is known as a squelch circuit.
Thanks a lot everyone, this gives me a lot to work with. I will report back!
