Determine the average of several sensors
Hello all
I need help or your advice for my project
I want to build an automatic irrigation system for my greenhouse. I want to determine the moisture of the soil with 5 soil moisture sensors and combine these values to an average value.
Can someone explain to me how I can now get these values from the 5 sensors to an average value?
Thanks in advance
Greetings Jonny
Given 5 values how would you calculate their average using pencil and paper ?
no i mean how i write the code
Start with how you would do it manually then you can convert it to code
Please post your code that gets the 5 values
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code
#define ventil 2
#define SENSOR_PIN0 A0
#define SENSOR_PIN1 A1
#define SENSOR_PIN2 A2
#define SENSOR_PIN3 A3
#define SENSOR_PIN4 A4
int sensorValue0 = 0;
int sensorValue1 = 0;
int sensorValue2 = 0;
int sensorValue3 = 0;
int sensorValue4 = 0;
  pinMode(ventil, OUTPUT);
   int sensorValue0 = analogRead(A0);
   int sensorValue1 = analogRead(A1);
   int sensorValue2 = analogRead(A2);
   int sensorValue3 = analogRead(A3);
   int sensorValue4 = analogRead(A4);
  Serial.println(sensorValue0);
  Serial.println(sensorValue1);
      Serial.println(sensorValue2);
    Serial.println(sensorValue3);
    Serial.println(sensorValue4);
If I told you that
sensorValue0 = 20
sensorValue1 = 25
sensorValue2 = 30
sensorValue3 = 10
sensorValue4 = 18
Show how you would work out the avarage on paper
divide and then multiply by 5
Try again
uint32_t add;
add = sensorValue0 + sensorValue1 + sensorValue2 + sensorValue3 + sensorValue4;
uint16_t divide;
divide = add / 5;
Serial.println(divide);
like so
Why don't you try it ?
There is a neater way of doing it but get it working the simple way first
