Yup, I got my Uno, my L293D Driver and my 12V, 1.7A bi-polar stepper hooked up and it shutters. Tried 3 different wiring set-ups using L293D with TIP120 transistors, different wiring without the transistors and the results are the same. a few shutters this way, then a few shutters the other way, maybe a bit of clicking with no movement, etc....
Reading the posts and feeling confident of my wiring and the proven sketches I used, I feel the problem is the wiring sequence (and/or polarity) to the stepper motor coils.
Does someone know a simple method of starting with two wires and hooking them up, confirming they are correct, and then the other two. I am terrified to try with without guidance for fear of damaging stuff.
I know the L293D says...
Pin 3 -> 1Y
Pin 6 -> 2Y
Pin 11-> 3Y
Pin 14->4Y
My stepper has a standard 4-pin connector with coil 1A, coil 1B, coil 2A, coil 2B
So, my default wiring has been...
1Y -> 1A
2Y ->1B
3Y ->2A
4Y ->2B
Other than that, I have been using wiring/code form the Arduino Stepper library (and other sources).
Tired to use my Pololu A4988 and nothing happened (but I might of blew that up earlier)
My external power supply is a regulated supply at 12V with 17A available (stepper only needs 1.7A). So lots of current available.
And yes, the L293D is hot to the touch. Actually, too hot to touch.
Biolar stepper two.docx (78.6 KB)
Bipolar stepper one.docx (25.6 KB)
datasheet-fit0278_1.pdf (84.1 KB)
