As I understand it ...
1 dashboard > 1 device t> 1 physical device,
is it possible to have
1 dashboard > 4 devices > 4 physical devices ?
my understanding :
A "Thing" represents one physical device and its set of Cloud variables
A dashboard is a separate layer on top : each widget on a dashboard is linked to a variable coming from a specific Thing, and different widgets on the same dashboard can each point to a different Thing, meaning a different physical device.
So your setup of 1 dashboard showing 4 devices (through 4 Things) is how I understand Arduino's IoT Cloud is designed to work.
There are constraints based on your plan limits, I'm not using it so I've lost track.
ā https://docs.arduino.cc/arduino-cloud/cloud-interface/dashboard-widgets/
Just to clarify are you saying you can have 1 dashboard (widgets) connected to 4 things connected to 4 devices?
I confirm that you can do this.
Even with the "Free" Arduino Cloud plan, there is no limit on the number of Widgets/Things per Dashboard. Likewise, there is no limit on the number of Devices you can create. However, there is a limit of two Things per account when using the "Free" plan. So you would need to use the "Maker" plan (or higher) in order to be able to have more than two Things:
