Is it possible to change the coulour the slider widget? instead og the default green
I know. I was just wondering if it was possible via code
Hi @Proietti. It is not possible to configure the color of the individual Arduino Cloud IoT Dashboard Widgets like the "slider". However, you can add other Widgets next to the slider, and control the color of those widgets:
The "Sticky Note" Widget allows you to add a text box with arbitrary fixed text to your Dashboard. The background color of this box is configurable.
The "LED" Widget adds a controllable color output element to the Dashboard.
Here is an example of using both of those additional Widgets with a slider:
Even though this is three separate Widgets, you could clearly communicate to the Dashboard viewer that they are part of a single unit by positioning them right next to each other, then giving more space between that Widget group and other Widgets on the Dashboard.
Also worth mentioning that we do provide two different themes for Arduino Cloud in general (not specific to a Dashboard). The above is with the light theme. Here is the dark theme:
To configure your theme:
- Click the icon at the top left hand corner of the Arduino Cloud window.
A navigation panel will open at the left hand side of the window. - Click the ●●● icon to the right of your account name at the top of that navigation panel.
A menu will open. - Click the "Theme..." menu item.
A submenu will open. - Select the theme you want from the menu.
Thanks
You are welcome. I'm glad if I was able to be of assistance.
Regards, Per
And where are the html files?
Press ctrl+I or right click on the slider and choose "inspect" then change the colors with the styles tab. It is kinda hard to explain in a forum. There are no HTML files for the website on GitHub so you have to use the browser to edit the HTML and CSS. I was not able to save the changes so it is not really with it.
Something I forgot to mention is the "Image" Dashboard Widget:
https://docs.arduino.cc/arduino-cloud/cloud-interface/dashboard-widgets/#image
This widget allows you to place any arbitrary image on your dashboard (note that this is not an image sent by the Thing). You could get quite creative with using this Widget to enhance the aesthetics of a Dashboard.
You could get even more fancy by using the "Image Map" Widget:
https://docs.arduino.cc/arduino-cloud/cloud-interface/dashboard-widgets/#image-map
Like the "Image" Widget, this is an arbitrary image displayed on the dashboard. However, the Image Map is interactive, including interaction with the Thing. The Image Map Widget is available with "Maker" and higher Arduino Cloud plans.
We also now offer some persistent color palette configuration capabilities as part of the "white label" feature offered as part of the "Team" and "Enterprise" Arduino Cloud Plans. If you are interested in learning more about the white labelling capabilities of these plans, you can contact the Arduino sales team via this form.
