I have a DFRobot Bluno Bluno. BT 4.0 4 Aoutputs, 4 Doutputs.
I am trying to detect when external devices are powered on wirelessly.
The beetle is such that it can only connect wirelessly or to Android /iphone devices.
I need it to connect or at least talk to a PC.
That is where the DFRobot BLE-Link comes in. Its basically a serial adapter that can link to the beetle.
You can configure them to auto connect via setting a specific mac addy.
You can also config them to act as master / slave.
My approach is such that, the Beetle is connected to PC through USB. I can interface with it via serial.
I plan to use the BLE Link Dongles to simply power up when external devices power up and the Beetle will attempt to pair with each of them.
If a pair is successful, I have a notification that device X is on
I have used/ adapted / written some code to accomplish this.
I store the known MAC addys of the external Link devices in an array.
I attempt to connect to each of the MACs one by one.
I attempt to send a request to the Link, if I get a reply, do X (Which for now is slow blink an LED)
My problem is that I get false triggers.
I plug a Link in, beetle link lights up.
I then try to connect to the known Link MAC ie:. 0x50658397CDC6
send, receive, blink.
Then I try to connect to fake MACs ie:. FakeMac1
somehow I still receive a return value.
I have placed many delays, and printouts to watch via serial monitor whats going on.
Right around connection attempt 7, you see it tries to connect to a FakeMac and still gets a return.
I have attached the code and the Log.
TIA
TEST.ino (3.44 KB)
Test_Serial_Mon_Log.txt (1.56 KB)
