I want to use an MAX9814 microphone to pick up sound/music and relay that to the MSGEQ7 and then to an Arduino to then make a WS2812 music visualizer. The MAX9814 has 1 OUT, which I guess transmits the sound to the next step or device, but the MSGEQ7 has and L and R input. I dont know how to remedy this. Can I or Should I just split the single output from the MAX9814 and split it into two and connect it to both L and R or should I just do one of the inputs? if so, which one? Pictured below are the MAX9814 microphone I Want to use instead of the 3.5mm jack configuration that is pictured in the other diagram of then MSGEQ7. As you can see, the msgeq7 has the L and R inputs but the MAX9814 has only 1 OUT. what do I do
