dfrobot v3 bluetooth module
hi,
i've bought a dfrobot v3 bluetooth module to connect to arduino MEGA 2560.
i was able to connect it to Arduino using TX and RX pins and to connect it to an android smartphone.
Then i used the serial monitor to communicate with smartphone.
The Serial monitor was able to send letters to the smartphone, but when i tried to send letters by smartphone to serial monitor it didn't receive anything.
connection: pin 16 (TX2) to RX module
pin 17(RX2) to TX module
BAUD RATE: 9600
i even tried to switch RX and TX pins, but it doesn't communicate on both sides.
can someone please help me?
trovez:
I guess you have now concluded that switching the pins was as about the most futile thing you could ever gave done. Since your code is a state secret, the best guess is that you have a serial input problem, so try here. It may be that you are simply listening on the wrong port.
You might also find the following background notes useful.
Hi Nick,
the code i used is one of the many code examples for bluetooth communication.
#include <SoftwareSerial.h>
SoftwareSerial SSerial(17, 16); //17 RX e 16 TX
int i = 1;
char a;
Serial.begin(38400);
while(!Serial) {}
Serial.println("ok");
SSerial.begin(38400);
if (SSerial.available()){
Serial.write(SSerial.read());
if (Serial.available()){
SSerial.write(Serial.read());
thanks for the advice. I'll read the post you have linked
trovez:
Clearly junk code, written by an idiot. Never run software serial on hardware serial pins, and I bet you have no good reason for running software serial on a Meg anyway, and probably never will.
Why do you believe that the module when in data mode is set for 38400 baud and not 9600?
