Salve gente, sono nuovo nell' uso di arduino e nello specifico di questa scheda da cui il nome del mio nuovo argomento.
DFPlayer - A Mini MP3 Player For Arduino
<https://www.dfrobot.com/index.php?route=product/product&product_id=1121>
This example shows the basic function of library for DFPlayer.
Created 2016-12-07
By [Angelo qiao](Angelo.qiao@dfrobot.com)
GNU Lesser General Public License.
See <http://www.gnu.org/licenses/> for details.
All above must be included in any redistribution
/***********Notice and Trouble shooting***************
1.Connection and Diagram can be found here
<https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#Connection_Diagram>
2.This code is tested on Arduino Uno, Leonardo, Mega boards.
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
SoftwareSerial mySoftwareSerial(11, 10); // RX, TX il 2 del df è il tx che va collegato al 3 dell' rx
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
pinMode(2,OUTPUT);
mySoftwareSerial.begin(9600);
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(10); //Set volume value. From 0 to 30
myDFPlayer.play(1); //Play the first mp3
digitalWrite(2,HIGH);
static unsigned long timer = millis();
/*if (millis() - timer > 3000) {
timer = millis();
myDFPlayer.next(); //Play next mp3 every 3 second.
if (myDFPlayer.available()) {
printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
A fronte di questo codice della libreria propria DFRobot DFPlayer, non riesco a suonare la canzone che ho inserito nella scheda sd. Nello specifico, la scheda sd ha una canzone in una cartella, ma in un modo a me sconosciuto ha suonato una volta, per poi non essere più stato in grado di rifarlo.
Inoltre, una volta lanciato il codice, l' autoparlante emette un brevissimo suono, ma non viene scritto nulla in seriale, e la scheda non mostra la luce blu di funzionamento.
Allego lo schema, ma lo ho realizzato in fisico. Grazie già in anticipo
